PPM sensor using the timer.
sashmich
Postby sashmich » Tue Jan 10, 2017 11:23 pm
Hello! How can I set the timer to work in capture mode? In my program, there is a block measuring speed, interrupt on it does not work exactly. There is a random error when using micros() function. I want to make it on a timer. I would be grateful for help with an example.
Sorry for my English :-).
Thank you.
Best regards, Alexander.
ddrown
Re: PPM sensor using the timer.
Postby ddrown » Wed Jan 11, 2017 4:05 am
This thread has some relevant info: http://www.stm32duino.com/viewtopic.php?f=3&t=1029
sashmich
Postby sashmich » Thu Jan 12, 2017 11:03 pm
Thanks. As I understand it is a problem.
ddrown
Postby ddrown » Fri Jan 13, 2017 3:09 am
sashmich wrote:Thanks. As I understand it is a problem.
Yeah, I found it easier to use STM32CubeMX to do input capture
Who is online
