Problem in Interfacing FTP628MCL103 Thermal printer with STM32
suyog44
Post by suyog44 » Wed Jan 11, 2017 10:30 am
First of all. i sincerly apologise for my english. I am begineer to STM32 MCU. I am trying to interface Fujitsu FTP629MCL103 Thermal Printer Module with STM32F100RBT6. I read the datasheet. But didn't got any clue how to do it. I started googling for it. Finally i start's search on interfacing i2c with stm32. I don't know whether i am correct or not. Help me out to solve the problem.
ftp-628mcl101_103.pdf
Thermal Printer Datasheet
(15.39 KiB) Downloaded 31 times
Re: Problem in Interfacing FTP628MCL103 Thermal printer with STM32
Post by stevestrong » Wed Jan 11, 2017 10:45 am
"The file is damaged and could not be repaired"
Can you upload a working PDF or a link to a valid file?
suyog44
Post by suyog44 » Wed Jan 11, 2017 11:03 am
stevestrong wrote:"The file is damaged and could not be repaired"
Datasheet: https://www.fujitsu.com/downloads/MICRO ... 01_103.pdf
Post by Pito » Wed Jan 11, 2017 11:16 am
Did you get the "printer module" - the mechanism with flex flat connector, or the "printer" - with USB/Centronics/Serial connectors? That is the first question..
suyog44
Post by suyog44 » Wed Jan 11, 2017 11:29 am
Pito wrote:Did you get the "printer module" - the mechanism with flex flat connector, or the "printer" - with USB/Centronics/Serial connectors? That is the first question..
I have the module with flex flat connector only. i dont have any parellel or serial interface module. I done some research on it, flex has been interfaced with any other MCU to get USART / UART .
Post by Pito » Wed Jan 11, 2017 12:55 pm
There is a lot of various signals, you would need a good datasheet with the protocols and commands.
The comm with MCU in the module works most probably via data_in, data_out, clk and latch signals. They are listed in the table.
Most probably it is SPI.
In case you would not find a ready library it might be a long way to go..
suyog44
Post by suyog44 » Fri Jan 13, 2017 5:27 am
Pito wrote:There is a lot of various signals, you would need a good datasheet with the protocols and commands.
I found something related to this. Might you get any clue from it. Its some how hard to me, as begineer.
https://drive.google.com/file/d/0Bz73yU ... sp=sharing
Post by Pito » Fri Jan 13, 2017 9:16 am
Did you ever browse "FTP628MCL103 Thermal printer with STM32" :?: :?:
https://www.youtube.com/watch?v=7YPirm2DoqM
https://github.com/romybompart/Thermal_ ... _stm32f107
Mind this project might be _very_ difficult when one is starting with MCUs..
suyog44
Post by suyog44 » Mon Jan 23, 2017 11:25 am
Pito wrote:Did you ever browse "FTP628MCL103 Thermal printer with STM32" :?: :?:
Thanks alot @Pito
