How to modify the external crystal frequency and configure PLL for stm32duino?
Star
Post by Star »
Hi, my Arduino IDE has stm32duino installed. I want to use the board of STM32F407, but I know that some boards use external crystal 25MHz and some use 8MHz. So if I want to configure the clock properly, where should I configure the PLL parameters?
Answers: 25
Re: How to modify the external crystal frequency and configure PLL for stm32duino?
you need to define your own
void SystemClock_Config(void)
in your variant, you can look at examples from existing variants e.g.
https://github.com/stm32duino/Arduino_C ... I.cpp#L148
WEAK void SystemClock_Config(void)
  /**Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  /**Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.PLL.PLLM = 25;
  RCC_OscInitStruct.PLL.PLLN = 336;
  RCC_OscInitStruct.PLL.PLLQ = 7;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) {
    Error_Handler();
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK) {
    Error_Handler();
  /* Ensure CCM RAM clock is enabled */
  __HAL_RCC_CCMDATARAMEN_CLK_ENABLE();
system clock and the peripheral clocks are linked, but that if you keep it to the standard published system clocks,
it is tuning the pll multipliers / dividers PLLM, PLLN, PLLP, PLLQ - this is for the stm32f4xx series.
other series may differ.
there is also a python script here, that you can use to explore the PLL configs.
viewtopic.php?t=78
