Remap PB2
efftek
Re: Remap PB2
Post by efftek » Fri Feb 24, 2017 10:35 am
Genious!
It was so much easier to move all the pins across to PB5..PB9 and redefine in the sketch and you, I get sensible results
No to edit the hearer file and try the graphics test .... I may be some time
Read Registers on STM32duino
controllers either read as single 16-bit
e.g. the ID is at readReg(0)
or as a sequence of 8-bit values
in special locations (first is dummy)
reg(0x0000) 00 00	ID: ILI9320, ILI9325, ILI9335, ...
reg(0x0004) 00 54 80 66	Manufacturer ID
reg(0x0009) 00 00 61 00 00	Status Register
reg(0x000A) 00 08	Get Powsr Mode
reg(0x000C) 00 06	Get Pixel Format
reg(0x0061) 00 00	RDID1 HX8347-G
reg(0x0062) 00 00	RDID2 HX8347-G
reg(0x0063) 00 00	RDID3 HX8347-G
reg(0x0064) 00 00	RDID1 HX8347-A
reg(0x0065) 00 00	RDID2 HX8347-A
reg(0x0066) 00 00	RDID3 HX8347-A
reg(0x0067) 00 00	RDID Himax HX8347-A
reg(0x0070) 00 00	Panel Himax HX8347-A
reg(0x00A1) 00 93 30 93 30	RD_DDB SSD1963
reg(0x00B0) 00 00	RGB Interface Signal Control
reg(0x00B4) 00 02	Inversion Control
reg(0x00B6) 00 02 02 3B 3B	Display Control
reg(0x00B7) 00 06	Entry Mode Set
reg(0x00BF) 00 00 00 00 00 00	ILI9481, HX8357-B
reg(0x00C0) 00 0E 0E 0E 0E 0E 0E 0E 0E	Panel Control
reg(0x00C8) 00 B0 B0 B0 B0 B0 B0 B0 B0 B0 B0 B0 B0	GAMMA
reg(0x00CC) 00 03	Panel Control
reg(0x00D0) 00 00 00	Power Control
reg(0x00D2) 00 00 00 00 04	NVM Read
reg(0x00D3) 00 00 94 88	ILI9341, ILI9488
reg(0x00DA) 00 54	RDID1
reg(0x00DB) 00 80	RDID2
reg(0x00DC) 00 66	RDID3
reg(0x00E0) 00 00 07 0C 05 13 09 36 AA 46 09 10 0D 1A 1E 0F	GAMMA-P
reg(0x00E1) 00 00 20 23 04 10 06 37 56 49 04 0C 0A 33 37 0F	GAMMA-N
reg(0x00EF) 00 00 00 00 00 00	ILI9327
reg(0x00F2) 00 58 04 12 02 22 22 FF 0A 90 14 88	Adjust Control 2
reg(0x00F6) 00 00 00 00	Interface Control
efftek
Re: Remap PB2
Post by efftek » Fri Feb 24, 2017 8:08 pm
SteveStrong
It still no workee! It reports the following;
TFT LCD test
TFT size is 240x320
*** Unknown LCD driver chip: 0
So, I was looking at Adafruit_TFTLCD_8bit_STM32.cpp and I wondered about two functions
uint16_t Adafruit_TFTLCD_8bit_STM32::readID(void)
   if (readReg32(0x04) == 0x8000) { // eh close enough
    // setc!
    writeRegister24(HX8357D_SETC, 0xFF8357);
    delay(300);
    //Serial.println(readReg(0xD0), HEX);
    if (readReg32(0xD0) == 0x990000) {
      return 0x8357;
  uint16_t id = readReg32(0xD3);
  //Serial.print("ID: "); Serial.println(id,HEX);
  if (id != 0x9341) {
    id = readReg(0);
  return id;
looks like it will only return 0x9341 OR 0 - mine is 0x9488 which I understand will work with a 9341 driver, it just has additional functions which obviously cant be made use of but when I uncomment the line Serial.print("ID: "); Serial.println(id,HEX); to see what the ID is, I get a 0 anyway.
BUT, that could all be explained by the following function
Adafruit_TFTLCD_8bit_STM32 :: Adafruit_TFTLCD_8bit_STM32(void)
: Adafruit_GFX(TFTWIDTH, TFTHEIGHT)
  //Set command lines as output
  //Note: CRH and CRL are both 32 bits wide
  //Each pin is represented by 4 bits 0x3 (hex) sets that pin to O/P
  TFT_CNTRL->regs->CRL = (TFT_CNTRL->regs->CRL & 0xFFFF0000) | 0x00003333;
    CS_IDLE; // Set all control bits to HIGH (idle)
    CD_DATA; // Signals are ACTIVE LOW
    WR_IDLE;
    RD_IDLE;
  //reset();
  //set up 8 bit parallel port to write mode.
  setWriteDir();
So, as Ive swapped the TFT_CTRL to PORTB and moved the control lines from A0..A5 to B5..B9, maybe this needs to be rewritten as B5..B7 are on CRL and B8 & B9, CRH
Would this be correct?
  TFT_CNTRL->regs->CRL = (TFT_CNTRL->regs->CRL & 0x000FFFFF) | 0x33300000;
    WR_IDLE;
    RD_IDLE;
    TFT_CNTRL->regs->CRH = (TFT_CNTRL->regs->CRH & 0xFFFFFF00) | 0x00000033;
    WR_IDLE;
    RD_IDLE;
  //reset();
  setWriteDir();
If not, please dont ridicule me, I'm just trying to apply my logic to the situation and I stand to learn from my mistakes.
Also, I took both ili9341cpp and ili9341.f files, copied them to ili9488.xxx and replaced every instance of 9431 with 9488 inside them and added #include ili9488.h in the Adafruit_TFTLCD_8bit_STM32.cpp file as a starting point to include ili9488 in the library. Is that the correct course of action?
Thanks again, Steve F.
Re: Remap PB2
Post by stevestrong » Fri Feb 24, 2017 11:02 pm
All that looks right, but ILI9341 was not tested, i only had ILI9328 to test so far, so it may happen that more will fail and has to be debugged...
I am actually glad if someone has time to add value to the lib.
Re: Remap PB2
Post by stevestrong » Sun Feb 26, 2017 6:44 am
Meanwhile I updated my repo to support an ILI9341-like display controller, so the ILI9341-related files has also been changed.
You could collect info about your display controller in David Prentice's repo (mcufriends_kbv) and add in to my one, in order to work with original Adafruit functions and GFX lib.
EDIT
You can see here the resulted graphicstest benchmark.
efftek
Re: Remap PB2
Post by efftek » Sun Feb 26, 2017 8:32 pm
Downloaded latest repo. Cheers.
Am going home Wednesday morning and probably won't get time to do anything more until im back in UK two weeks later as Bev probably has a list of jobs for me!
Steve F.
