trying to understand how the compiler works...
Post by stevestrong » Sun Mar 19, 2017 9:55 am
I am still fighting to understand what is determining the compiler to mess up my code, or to generate a code which I don't expect...
Just toggling some GPIOs on maple mini clone:
#include <libmaple/gpio.h>
// set pins to output the 8 bit value
#if 1
 #define write8(c) {digitalWrite(PB0, (c&BIT0)?HIGH:LOW); \
					digitalWrite(PB1, (c&BIT1)?HIGH:LOW); \
					digitalWrite(PB2, (c&BIT2)?HIGH:LOW); \
					digitalWrite(PB3, (c&BIT3)?HIGH:LOW); \
					digitalWrite(PB4, (c&BIT4)?HIGH:LOW); \
					digitalWrite(PB5, (c&BIT5)?HIGH:LOW); \
					digitalWrite(PB6, (c&BIT6)?HIGH:LOW); \
					digitalWrite(PB7, (c&BIT7)?HIGH:LOW); }
#else
 void write8(uint8_t c) {
 /* fast write
 #define write8(c) { uint32_t val = (((c^0x00FF)<<16) | c); \
					GPIOB->regs->BSRR = val; }
	Serial.begin(); // USB port
	//while ( !Serial.isConnected() ) ; // wait for USB connection
	delay(6000);
	Serial.println("\n***** Port pin toggle test *****\n");
	GPIOB->regs->CRL = 0x33333333; //	// set the lower 8 bits as output
uint8_t c = 0;
#if 1
	write8(c++);
#else
	write8(c);
	c++;
Problem:
In this configuration PB0..2 won't toggle at all, PB3..7 and up will toggle as I would expect from PB0..4.
Solution:
If I set either line 6 or line 47 to "#if 0", then all pins toggle as expected.
It seems that there is an unlucky combination of using several "digitalWrite()" and variable increment (c++) within a define.
Can someone explain me what is actually happening here, what am I doing wrong?
STM32_GPIO_toggle_test.ino
(1.32 KiB) Downloaded 7 times
[SOLVED] trying to understand how the compiler works...
Post by stevestrong » Sun Mar 19, 2017 10:09 am
OK, I think that the compiler generates the following code from #define write8(i++):
digitalWrite(PB0, (i&BIT0)?HIGH:LOW); i++;
digitalWrite(PB1, (i&BIT1)?HIGH:LOW); i++;
digitalWrite(PB2, (i&BIT2)?HIGH:LOW); i++;
digitalWrite(PB3, (i&BIT3)?HIGH:LOW); i++;
digitalWrite(PB4, (i&BIT4)?HIGH:LOW); i++;
digitalWrite(PB5, (i&BIT5)?HIGH:LOW); i++;
digitalWrite(PB6, (i&BIT6)?HIGH:LOW); i++;
digitalWrite(PB7, (i&BIT7)?HIGH:LOW); i++;
It just adds the variable increment after each code line.
This would explain why the bits are shifted by 3 bits (multiplied by 8), but the question is: why would the compiler do this?
Answer:
Because the compiler replaces all "i" instances by "i++"...
ddrown
Re: [SOLVED] trying to understand how the compiler works...
Post by ddrown » Sun Mar 19, 2017 3:39 pm
stevestrong wrote:OK, I think that the compiler generates the following code from #define write8(i++):
Answer:
Yup, you got it. You can look to inline functions as another alternative.
Re: trying to understand how the compiler works...
Post by Rick Kimball » Sun Mar 19, 2017 5:00 pm
If I'm using a macro i tend to avoid things like post increment or addition or anything other than passing a value to it.
Who is online
Users browsing this forum: No registered users and 2 guests
