Serial.write problem
vitor_boss
Re: Serial.write problem
Postby vitor_boss » Wed Apr 19, 2017 7:16 pm
edogaldo wrote:
vitor_boss wrote:This is the problem, before that call the code use the same loop for a 288 bytes Serial.write and a lot of Serial.print and all work fine, only that lines aren't giving outputs
code is at https://github.com/noisymime/speeduino/ ... /comms.ino
Hi vitor, I can't see any uint8_t/uint16_t in the code you linked, it would be better if you post the real code you are using..
I changed the code trying to make it work but doesn't. I have changed int to uint16_t to keep data alignment across platforms.
victor_pv wrote:
stevestrong wrote:If it is about this part of your code, then it will not work at least because sizeof(response) is actually not explicitly defined, but only indirectly through a variable value. So I assume you have a bug in your code.
Didn't you have some compiler warnings?
I think I agree with Steve on that. If I understand it right, sizeof is calculated at compile time, but you seem to use a variable to set the size.
Wouldn't be better to change the serial.write line to this?
Serial.write((byte *)&response, npage_size[currentPage]);
As to why would it work on a different mcu, you probably should check if the Serial.write implementation is the same or not.
Thanks, I will try that
vitor_boss
Postby vitor_boss » Wed Apr 19, 2017 7:18 pm
stevestrong wrote:vitor, could you please explain what exactly means "it didn't work"?
Are any bytes sent over serial? Are they wrong? Any serial monitor log available to show the problem?
I would try this way:
Serial.write(response, sizeof(response));
It seems that an 16 bit value (x) is added and stored as an 8 bit value (response[n]), so that an overflow can occur. Is this wanted?
I have no bytes output
Edit: Changed code to yours and don't work too.
vitor_boss
Postby vitor_boss » Wed Apr 19, 2017 7:25 pm
That is my software log:
19/04/17 16:16:27 :Info: Activating page: 1
19/04/17 16:16:27 :Time: 0:10.602: SENT 2 bytes iwd=10, 2 bytes
x50 x01                                                               P.
19/04/17 16:16:27 :Time: 0:10.613: SENT 1 bytes iwd=10, 1 bytes
x56        V
19/04/17 16:16:28 :Debug: Read page time: 174ms.
19/04/17 16:16:28 :Time: 0:10.763: READ 288 bytes, 288 bytes
x00 x00 x00 x00 x00 x00 x00 x00 x00 x00 x00 x00 x00 x00 x00 x00       ................
19/04/17 16:16:28 :Info: Activating page: 2
19/04/17 16:16:28 :Time: 0:10.785: SENT 2 bytes iwd=10, 2 bytes
x50 x02                                                               P.
19/04/17 16:16:28 :Time: 0:10.795: SENT 1 bytes iwd=10, 1 bytes
x56        V
Time: 0:13.797: READ Timout after 0 bytes, Expected:64, actual read:0 Raw buffer
19/04/17 16:16:31 :Debug: Time:13.796s. Instruction:
vitor_boss
Postby vitor_boss » Wed Apr 19, 2017 7:37 pm
BennehBoy wrote:Can you not just write out a single byte at a time in the loop?
I'm using Serial.write in some ecu code, but only 1 byte at a time.
That worked for 64 bytes, thank you, but on Line 773 with a 192(3x64) bytes if fails too.
Edit: worked for first reading, next readings only output 50 bytes
Postby stevestrong » Thu Apr 20, 2017 9:40 am
If it works once, it should work always.
Your software is buggy.
I would suggest to get rid (remove) of sizeof(response), and use either previously defined constants or appropriate variables, where needed.
Also, define only once the "response[]" buffer of a maximum size (192?), and control the length of data as said.
Postby victor_pv » Thu Apr 20, 2017 8:25 pm
vitor_boss wrote:Thanks, I will try that
Did you try changing the line to this as I suggested?
vitor_boss
Postby vitor_boss » Fri Apr 21, 2017 10:14 am
Yes, no output bytes either.
Postby ag123 » Fri Apr 21, 2017 10:24 am
try with
Serial.write("0123456789", 10);
at the code location, commenting the original codes
you could make a longer string which is similar to the size that you need.
this may help to troubleshoot it. if necessary you may like to trouble shoot with a 'hard coded' byte pattern resembling your output and calling it there
and in addition to test if the particular byte pattern is anticipated there e.g. check the byte sequence for correctness and turn on the led if it is correct
note that with usb-serial you are also dealing with a virtual com port on the os side e.g. windows. i'm not too sure if windows etc may be doing things like software flow control and sequences which means that control-q and control-s characters may stall your windows terminal from receiving the data
https://en.wikipedia.org/wiki/Software_flow_control
you may need to 'escape' those control-q, control-s sequences and substitute with an encoding that doesn't use those
just 2 cents
Postby victor_pv » Fri Apr 21, 2017 3:46 pm
Quick question, shouldn't you be using just "response" rather than "(byte *)&response" since response is an array?
Such as:
Serial.write(response, npage_size[currentPage]);
vitor_boss
Postby vitor_boss » Sun Apr 23, 2017 2:48 pm
Such as:
Sorry for delay, yes I have tested this and no output too.
I have disables windows PEPS buffers and now it's working. Seems to this UART implementation is not compatible with UART v16550 with supports PEPS
Who is online
Users browsing this forum: No registered users and 2 guests
