Issues with analogRead() for PB0 on Nucleo G431KB
sesh
Post by sesh »
I am trying to use pin PB0 in analogRead mode on a Nucleo32 G431KB. This is the code that I am using:
#include <Arduino.h>
    pinMode(PB0, INPUT_ANALOG);
    int analogValue = analogRead(PB0);
    Serial.println("Analog Value (PB0): " + String(analogValue));
When I run this code and change the voltage applied to the pin, there is no response on the serial monitor. Currently, the serial monitor outputs a value, but this value dones't change in accordance with the voltage applied.
I have tested analog read on this pin with HAL using STM32CubeIDE and it works without issues. How do I resolve this issue and make this pin work using stm32duino?
by fpiSTM » Thu Nov 16, 2023 10:18 am Go to full post
gauthierDCC
Re: Issues with analogRead() for PB0 on Nucleo G431KB
Post by gauthierDCC »
Try with to add that in your setup()
analogReadResolution(12);
sesh
Post by sesh »
Tried that, it still doesn't work
Hi @sesh
In fact, hte PB0 has not been declared as analog pin. That's why you get this issue.
Could you file an issue on GitHub, then I will do the update.
https://github.com/stm32duino/Arduino_Core_STM32/issues
leaderstutter
Post by leaderstutter »
Thanks, problem solved for me. :)
Return to “PR's bugs and enhancements”
