WeAct stm32F103CB HID Bootloader question
PGSmick
Post by PGSmick »
Hello.
I need to be educated on this a bit.
I just bought a bunch of WeAct stm32F103CB BluePills whose internal LED is connected to pin PB2. I have an STLink and the STM32CubeProgrammer software installed. I couldn't find a hid_generic_pb2.bin file to flash so I just used the hid_generic_pc13.bin file that I have used for other variants of blue pills.
Everything seems to work fine. I can upload a sketch from the Arduino IDE using the HID Bootloader upload method connected via a USB cable and I can make the LED blink by specifying the PB2 pin. I can upload sketches repeatedly with no difficulty. The serial monitor works fine. So all's good, no?
So, am I missing anything by having used the _pc13.bin file that I used? What is the purpose of having all those different bin files? If it matters which bin file I use, how can I get one that's designed for the board with the LED on pin PB2?
A million thanks in advance.
Peter
Vassilis
Re: WeAct stm32F103CB HID Bootloader question
Post by Vassilis »
The only difference among these bin files is the pin definition of the on-board LED used by the HID bootloader to indicate its status.
If you don't care about the status indicator, you can use any of these bin files.
The easy way is to edit the file: STM32_HID_Bootloader/bootloader/F1/Inc/config.h
and replace the following lines
#elif defined TARGET_GENERIC_F103_PB12
	#define LED1_CLOCK		RCC_APB2ENR_IOPBEN
	#define LED1_BIT_0		SET_BIT(GPIOB->CRH, GPIO_CRH_CNF12_0 | GPIO_CRH_MODE12)
	#define LED1_BIT_1		//CLEAR_BIT(GPIOB->CRH, GPIO_CRH_CNF12_1)
	#define LED1_MODE
	#define LED1_OFF		WRITE_REG(GPIOB->BSRR, GPIO_BSRR_BS12)
	#define LED1_ON			WRITE_REG(GPIOB->BRR, GPIO_BRR_BR12)
with these:
	#define LED1_BIT_0		SET_BIT(GPIOB->CRH, GPIO_CRH_CNF2_0 | GPIO_CRH_MODE2)
	#define LED1_BIT_1		//CLEAR_BIT(GPIOB->CRH, GPIO_CRH_CNF2_1)
	#define LED1_MODE
	#define LED1_OFF		WRITE_REG(GPIOB->BSRR, GPIO_BSRR_BS2)
	#define LED1_ON			WRITE_REG(GPIOB->BRR, GPIO_BRR_BR2)
Recompile the HID Bootloader source code and use the hid_generic_pb12.bin file
Vassilis Serasidis
https://www.serasidis.gr
PGSmick
Post by PGSmick »
Thanks very much!
