change serial interrupt routine
octavio
Post by octavio » Thu Oct 05, 2017 6:34 pm
Hello,how can i declare a interrupt routine for USART3 (Serial2).
Re: change serial interrupt routine
Post by victor_pv » Thu Oct 05, 2017 8:02 pm
Did you see one in the core? if there is one, it's probably weak. Otherwise there may be an attachInterrupt method or something like it to piggyback yours to the core one.
That's how the DMA channels work as an example. Rather than declare an ISR, you just use the attach function to pass your ISR pointer to the core, and it will be called from the core ISR.
octavio
Post by octavio » Thu Oct 05, 2017 9:19 pm
" there may be an attachInterrupt method"
I did not found it.
Post by victor_pv » Thu Oct 05, 2017 9:21 pm
I did not found it.
Did you see if the core ISR is declared weak? most are.
octavio
Post by octavio » Thu Oct 05, 2017 9:26 pm
https://github.com/rogerclarkmelbourne/ ... usart_f1.c
void __irq_usart2(void)
Not sure if this is the code,but it seems is declared the normal way.
octavio
Post by octavio » Thu Oct 05, 2017 9:29 pm
void usart_init(usart_dev *dev) {
    rb_init(dev->rb, USART_RX_BUF_SIZE, dev->rx_buf);
    rb_init(dev->wb, USART_TX_BUF_SIZE, dev->tx_buf);
    rcc_clk_enable(dev->clk_id);
    nvic_irq_enable(dev->irq_num);
it seems that the vector is hardcoded.
Post by victor_pv » Thu Oct 05, 2017 9:48 pm
Seems like it, and the core handler, here, doesn't show any provision to call a user function either:
https://github.com/rogerclarkmelbourne/ ... vate.h#L40
You can change the vector ni one of this files (I forgot how they work with each other). Also I believe there was a thread about this some months back:
https://github.com/rogerclarkmelbourne/ ... nce/isrs.S
https://github.com/rogerclarkmelbourne/ ... or_table.S
https://github.com/rogerclarkmelbourne/ ... ymbols.inc
This was the thread:
viewtopic.php?f=3&t=1816&hilit=usart+isr+weak
octavio
Post by octavio » Sat Oct 07, 2017 7:54 pm
Thanks,i did the same as Riva and it seems to work.
