Delay less than 1 µs ?
Re: Delay less than 1 µs ?
Post by Rick Kimball » Tue Nov 07, 2017 4:34 pm
You should search in code snippets for a post I made about using the DWT peripheral for cycle counting
Post by Rick Kimball » Tue Nov 07, 2017 11:34 pm
I used Pito's code to create a 100kHz toggle using the DWT timer. Granted you aren't going to be able to create a 10nsec pulse, as the the cycle count at 72 MHz is 13.888 nsec, however you can do accurate usec pulses using the DWT peripheral.
// accurate micro second pin toggle ..
// DWT defines from Pito's post
// * note, I made CpuGetTicks volatile
#define DWTEn()         (*((uint32_t*)0xE000EDFC)) |= (1<<24)
#define CpuTicksEn()    (*((uint32_t*)0xE0001000)) = 0x40000001
#define CpuTicksDis()   (*((uint32_t*)0xE0001000)) = 0x40000000
#define CpuGetTicks()   (*((volatile uint32_t*)0xE0001004))
  DWTEn();
  CpuTicksEn();
  pinMode(LED_BUILTIN,OUTPUT); // for blue pill this is the PC13
const uint32_t usec_delay = 5; // 5usecs == 100kHz toggle
const unsigned usecs_in_cycles = 72*usec_delay; // 72 cycles in 1 usec with 72MHz system clock
  static unsigned toggle;
  static uint32_t prev;
  while(1) {
    uint32_t curr = CpuGetTicks();
    // toggle LED pin every usec_delay
    if ( (curr-prev) >= usecs_in_cycles  ) {
      prev = prev + usecs_in_cycles;
      toggle^=1;
      GPIOC->regs->BSRR = ((1 << 13 ) << 16) | (toggle << 13);
edogaldo
Post by edogaldo » Wed Nov 08, 2017 11:14 am
acronis wrote:
Tue Nov 07, 2017 2:06 pm
you commented out "nop"
loop ()
digitalWrite(PA5,LOW);
//asm volatile ("nop");
digitalWrite(PA5, HIGH);
the time remains the same - 200 ns at the switching state on pine (((
If you want to achieve clock level speed you need to go with assembly..
Here a sample asm sketch to toggle PA5 on F407:
  pinMode(PA5,OUTPUT);
  //GPIOA.regs->BSRRL = 0x0005;
  //GPIOA.regs->BSRRL = 0x0500;
  asm volatile ("mov r0,#0x0018");
  asm volatile ("movt r0,#0x4002");
  asm volatile ("mov r1,#0x0005");
  asm volatile ("mov r2,#0x0500");
  asm volatile ("myloop: strh r1, [r0]");
  asm volatile ("strh r2, [r0]");
  asm volatile ("strh r1, [r0]");
  asm volatile ("b.n myloop");
This is probably the fastest performance you can get and at this level you can better evaluate the difference of introducing an asm "nop"..
Cheers, E.
acronis
Post by acronis » Wed Nov 08, 2017 12:17 pm
YOU very much.
I will try to do so
edogaldo
Post by edogaldo » Wed Nov 08, 2017 1:18 pm
YOU very much.
I will try to do so
Sorry, I made a mistake with setting BSRR..
Here a correction anyway I'm not able to test it on the F407 so I cannot guarantee there are no more errors:
  //GPIOA.regs->BSRR = 0x0020; // set PA5
  //GPIOA.regs->BSRR = 0x00200000; // clear PA5
  asm volatile ("ldr r0,#0x40020018"); // r0 -> GPIOA.regs->BSRR
  asm volatile ("mov r1,#0x0020"); // r1 -> mask to set PA5 HIGH in BSRR
  asm volatile ("lsl r2,r1,#0x10"); // r2 -> mask to set PA5 LOW in BSRR
  for(;;)
    asm volatile ("str r2, [r0]");
    asm volatile ("str r1, [r0]");
