some sectors are write protected
dev
Re: some sectors are write protected
Post by dev » Sun Nov 12, 2017 6:46 pm
@Rick, I was facing problem while flashing using stlink utility but i could flash using arduino ide.
But after flashing USB bootloader, i couldn't flash using STM32duino bootloader. i used this method before(6 months ago).
@pito, i tried suggested binary too. But not working for my board. Board is detected as COM port but not able to flash the code using usb bootloader.
Post by Pito » Sun Nov 12, 2017 6:48 pm
Did you flash the bootloader maple_mini_boot20.bin binary with the ST-Link dongle??
Do you use the Maple Mini board? Post a link to your board, plz.
dev
Post by dev » Sun Nov 12, 2017 6:52 pm
Yes, i flashed using stlink clone dongle. I have following board with me.
STM32Mini (1).jpg (132.99 KiB) Viewed 129 times
Post by Pito » Sun Nov 12, 2017 6:53 pm
That is not Maple Mini board.
I was flashing maple mini with st-link clone and st-link utility
You indicate from very beginning your board is Maple Mini.. :(
That is the BluePill board..
This is the binary for your board:
https://github.com/rogerclarkmelbourne/ ... 0_pc13.bin
dev
Post by dev » Sun Nov 12, 2017 6:57 pm
ohh...yes. Sorry for that. But i did mentioned stm32f103c8t6.
i know some threads were going on about name of boards.
yes. I have blue pill board.
Post by Pito » Sun Nov 12, 2017 7:00 pm
Ok, try to flash the BluePill bootloader binary with the ST_Link dongle.
Tell us exactly what is the problem during flashing the bootloader binary with the ST_Link Utility.
We'll try to help you, you have to describe in detail what you have done so far.
The flashing the bootloader with the ST_Link is easy.
Do not power the board from both BP usb and ST_Link, choose only one of them. Use 3.3V only (ie. from ST_Link dongle do use 3.3V).
Sometimes the ST_Link Utility cannot connect. Select Target->Settings->Mode - "Connect under Reset" and press reset button on the BP immediately after you click Target->Connect.
dev
Post by dev » Sun Nov 12, 2017 7:11 pm
I am flashing using STlink dongle only, but i get the error continously. I have to reset the board 3-4 times for one flash(which was not the case before two days).
I flashed binary you mentioned. and flashing code as
  // initialize digital pin PB1 as an output.
  pinMode(PC13, OUTPUT);
  digitalWrite(PC13, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(100);              // wait for a second
  digitalWrite(PC13, LOW);    // turn the LED off by making the voltage LOW
  delay(300);              // wait for a second
(this code works if flashed via stlink).
after that i selected stm32duino bootlader and COM port which came as 10.
the hit on UPLOAD button then i got following error on output window.
maple_loader v0.1
while uploading LED was blinking for 1 sec and then stopped following line were on output window.
which didn't find proper dfu bootloader i guess.
Post by Pito » Sun Nov 12, 2017 7:25 pm
Stop messing with Arduino sketches, unless you have flashed the bootloader successfully.
How do you flash the bootloader with "ST_Link dongle"?
Do you use the ST_Link Utility in order to flash the bootloader??
What errors you get when flashing the bootloader??
What do you see on the BP LED after you flashed the bootloader?
Post by RogerClark » Sun Nov 12, 2017 7:26 pm
Sounds like the USB pullup resistor problem
Post by Rick Kimball » Sun Nov 12, 2017 7:29 pm
"A rose by any other name would smell as sweet"...
Maybe those words ring true with Shakespeare and love. Unfortunately, the name of the board is important here. I hate wasting my time on this kind of confusion. Why do people find it so hard to identify what they are using?
