[SOLVED] Select the SPI bus within a function
aster
Post by aster » Sat Nov 18, 2017 1:12 pm
Hello,
I try to explain the title of the topic. I have a library which use spi, but to select spi1 or 2 i need to edit the .cpp file
I would like to do it with a function, i tried it but i get errors since the declaration of "SPIClass SPI_bus(2);" seems to need to be declared as global
Any simple workaround or am i missing something?
Re: Select the SPI bus within a function
Post by victor_pv » Sat Nov 18, 2017 2:21 pm
You could try using a pointer to SPI instead, then the pointer can be changed in a function to one port or the other.
Within your code you will likely have to change all spi.transfer etc to spi->tranfer (so -> rather than .)
Example:
Original
spi.transfer(xx,nn);
New:
SPIClass *spi_pointer = &SPI;
spi_pointer->transfer(xx,nn);
And you can add a new function to change the value of spi_pointer any time to a different pointer. Make sure it's always valid so your code doesn't crash.
I believe Steve linked to a new ILI9341 driver where he implemented that. I have done similar in another driver. Here I change the value of the pointer in begin(SPIClass* spi):
https://github.com/victorpv/reflowOvenC ... 63C.h#L316
So in my code I can have for example SPI2 declared, to be the second port, then I can do this:
tft.begin(&SPI2);
SPI2 is declared global in my main sketch, only the pointer is passed to the tft class. In my opinion SPI port objects (any hardware for tht matter) should always be global, since if you declare 2 copies of the same object to manage the same hardware decide, you are likely end up with unexpected results when both make changes to hardware registers that exist only once from 2 different places, each expecting their value to not be changed by another piece of code.
Post by stevestrong » Sat Nov 18, 2017 2:36 pm
Another example from here: https://github.com/stevstrong/Ethernet_STM32
You have to declare an SPI class object with appropriate SPI port number (1 or 2 for F1, 1..3 for F4)
SPIClass mSpi(1); // you can use 1..2 for F1, 1..3 for F4)
Then you need to call a function in setup():
Ethernet.init(mSpi, PA4); // SPI class object, chip select pin on your choice
Here, the SPI object will be passed as reference and not as pointer, so you must not use "->" the source:
mSpi.transfer(0x55);
Post by RogerClark » Sat Nov 18, 2017 7:01 pm
You may be able to use setModule(2)
see
viewtopic.php?t=423
aster
Post by aster » Tue Nov 21, 2017 6:30 pm
thank very much to victor, stevestrong and roger
at the end since it wasn't my library and i didn't want to override the structure too much i used setModule but your solution are very interesting!
