OverClock. at Runtime ~90MHz
alexandros
Post by alexandros » Thu Nov 23, 2017 7:12 am
Hello there ,
is there any way to overclock the speed of the CPU at Runtime , but not with fullspeed 128Mhz , but somewhere around like 90Mhz.
zoomx
Re: OverClock. at Runtime ~90MHz
Post by zoomx » Thu Nov 23, 2017 3:32 pm
I wander if it is also possible to go down, in other words it it is possible to change clock speed at runtime, taking in account that serial baudrate and other things will change too.
RogerClark
Post by RogerClark » Thu Nov 23, 2017 8:13 pm
The LibMaple Core is not designed to allow changes to clock frequency at runtime
If you look at the places where the F_CPU definition is used
https://github.com/rogerclarkmelbourne/ ... _cpu&type=
It’s used in multiple places
All of those would need to be changed to use a variable rather than a definition, and some macros changed to functions etc
Additionally, parts of the system startup code e.g. places that set the hardware clock PLL would need to be run, and I susoect the startup code would need to be broken into smaller modules, or you would need to duplicate some code
It’s an interesting project if you want to take it on, as you could also integrate stopping and restarting the USB, so the processor could switch to overclocked for a short period, to do intensive processing, then switch back to 72MHz to run USB
Or, it may be possible to run at 128MHz for a few milliseconds without impacting the USB at all.
Please bear in mind, that at 96Mhz the USB will not work. It only works at 72MHz and 48MHz as this is a limitation in the MCU internal hardware
alexandros
Post by alexandros » Fri Nov 24, 2017 8:20 am
Thanks Roger!!
Any code snippet for that??
edogaldo
Post by edogaldo » Fri Nov 24, 2017 9:03 am
Looking at the usage of F_CPU looks like it should be enough to define F_CPU as a multiple of HSE (from 1*HSE to 16*HSE) to get the expected clocking (in a static way though).
Instead I'm in doubt with:
#define SYSTICK_RELOAD_VAL (F_CPU/1000) - 1
I think it should be better as:
#define SYSTICK_RELOAD_VAL (F_CPU/1000 - 1)
because else there's the risk that, once converted the macro, the resulting expression will not be the expected one.
Cheers, E.
RogerClark
Post by RogerClark » Fri Nov 24, 2017 10:32 am
Thanks Roger!!
No. I'm not aware of any code to change the clock speed during at runtime.
Pito
Post by Pito » Fri Nov 24, 2017 11:19 am
You can change the cpu clock at runtime with F103.
I did it on F103 in past (with mecrisp forth) and it worked perfectly. I was changing on-the-fly the clock in a loop in a sequence like 72MHz/8MHz/128MHz/48MHz without a crash. Mind the clock's PLL setting (the phase loop needs to lock itself at the new freq) takes some time thus there always will be a small "time gap" while the PLL locks.
You have to take the clock setting routine from the core, and you want to add ticks and baudrate settings change such you stay consistent with ms/micros and uart speed. I did not test with USB as it is supported by a few clock freqs only.
void set_clock(uint32_t clk_khz, uint32_t baudrate) {
set_cpu_clk(clk_khz);  // see core
set_ticks(clk_khz);  // see core
set_baudrate(baudrate);  // see core
#define baudrate 115200;
set_clock(8000, baudrate);
set_clock(128000, baudrate);
set_clock(48000, baudrate);
set_clock(72000, baudrate);
set_clock(96000, baudrate);
alexandros
Post by alexandros » Fri Nov 24, 2017 11:51 am
WOWW pito!! :shock: :o :o
Pito
Post by Pito » Fri Nov 24, 2017 11:57 am
The big Q is why do you need such on-the-fly clock switch.
Energy?? You may run BluePill at 96MHz easily and go sleep when needed.
The total energy spent might be much lower than when switching between various freqs.. ;)
Or do you want to have the USB available (ie at 48/72MHz) and only switch to 96/128MHz in order to speed up some calcs??
alexandros
Post by alexandros » Fri Nov 24, 2017 12:08 pm
Or you do want to have USB available (ie at 48/72MHz) and switch to 96/128MHz in order to speed up some calcs??
i just want to test if i get good results in specific parts of the code with 96MHZ and the rest with 72
i notice thought a temperature raise in CPU when overclocking OK thats normal
