INPUT_PULLDOWN
Re: INPUT_PULLDOWN
Post by dannyf » Sat Dec 02, 2017 1:22 pm
but almost work
almost surely, except when it doesn't.
a similar trap exists on older the older luminary chips: if your code executes so fast that it disables the debug pins before the connection is made, you will never be able to debug the chip. A recent example is here: https://dannyelectronics.wordpress.com/ ... -lock-out/
luminary's "work-around" is to insert a large delay routine at the very beginning of user space to allow the debugger to kick in before doing anything, so if your code isn't working perfectly, you can still program it.
Re: INPUT_PULLDOWN
Post by RogerClark » Sat Dec 02, 2017 7:29 pm
There are 2 ways to get a STLink to connect even if the pins are disable by the firmware
Put the jumpers on Boot0 to High
Or
use connect under reset
aster
Re: INPUT_PULLDOWN
Post by aster » Sat Dec 02, 2017 9:52 pm
shouldn't be a good idea to put this delay "before" the setup?
in arduino it is something like this:
void main() {
   init();
   setup();
   while (1)
       loop();
i guess it is the same here, the delay could be added between init() and setup(). do you think that people usually need to have the board running immediately the setup() or that 1s of delay could be headache saving?
anyway you should add somewhere in keyword.txt
INPUT_PULLDOWN LITERAL1
this would make the arduino ide colour INPUT_PULLDOWN light blue as INPUT_PULLUP, INPUT, OUTPUT ecc ecc
Re: INPUT_PULLDOWN
Post by RogerClark » Sat Dec 02, 2017 9:56 pm
I can't see how moving the order of when the SWD pins are disabled will help with connecting via STLink etc
The difference in time with be micoseconds
