[SOLVED] EEPROM i2c - use negative values
pokemon99
Post by pokemon99 » Fri Dec 08, 2017 9:06 am
Good afternoon.
Tell me by using External I2C EEPROM,
An example took this one.
https://playground.arduino.cc/Code/I2CEEPROM24LC512
Everything works, but I would like to record negative values.
Re: EEPROM i2c
Post by stevestrong » Fri Dec 08, 2017 9:41 am
Change uint8_t to int8_t.
pokemon99
Re: EEPROM i2c
Post by pokemon99 » Fri Dec 08, 2017 12:43 pm
void writeEEPROM(int deviceaddress, unsigned int eeaddress, int data)
  Wire.beginTransmission(deviceaddress);
  Wire.write((int)(eeaddress >> 8));   // MSB
  Wire.write((int)(eeaddress & 0xFF)); // LSB
  Wire.write(data);
  Wire.endTransmission();
  delay(2);  //no puede ser 0, ya que la velocidad de acceso al EEPROM es muy alta
int readEEPROM(int deviceaddress, unsigned int eeaddress)
  int rdata = 0;
  Wire.requestFrom(deviceaddress, 1);
  if (Wire.available())  rdata = Wire.read ();
  return rdata;
int EEPROM_int_read(int addr) {
  byte raw[2];
  for (byte i = 0; i < 2; i++) raw[i] =
      readEEPROM(disk1, addr + i);
  int &num = (int&)raw;
  return num;
void EEPROM_int_write(int addr, int num) {
  byte raw[2];
  (int&)raw = num;
    writeEEPROM(disk1, addr + i, raw[i]);
  EEPROM_int_write(200, -2555);
  delay(100);
  val = -65536 + EEPROM_int_read(200);
Re: EEPROM i2c
Post by stevestrong » Fri Dec 08, 2017 12:46 pm
Do you know how many bits wide is the variable of type "int" for STM32 ?
Hint: is not identical with that for AVR chips.
I recommend to always use the typedefs int8_t, uint8_t, int16_t, uint16_t, int32_t, uint32_t in your code, in this way you know how many bytes/bits are you working with.
Re: EEPROM i2c
Post by dannyf » Fri Dec 08, 2017 1:06 pm
negative values are the same as positive (unsigned) values. the code is written to be able to handle both.
pokemon99
Re: EEPROM i2c
Post by pokemon99 » Fri Dec 08, 2017 1:11 pm
Thank you. I replaced int with int16_t, everything is fine.
delay(100);
val = EEPROM_int_read(200);
