AC Dimmer
pokemon99
Re: AC Dimmer
Post by pokemon99 » Mon Dec 11, 2017 11:46 am
Yes, this scheme, I know. Many even use it to power the MCU, but I'm wary of it.
Re: AC Dimmer
Post by ahull » Mon Dec 11, 2017 12:17 pm
It is no more dangerous than that high power resistor. Neither has galvanic isolation.
Re: AC Dimmer
Post by victor_pv » Mon Dec 11, 2017 4:12 pm
Andy are you suggesting the capacitive dropper+ the opto?
The opto provides isolation, so the schematic from pokemon has isolation.
About using it without cross detection, you could modulate power by turning on for a number of cycles, then off for a number of cycles, rather than for a percentage of each cycle.
In that way you may turn on in the middle of a cycle, which is not ideal, but then you stay for for say the period of 200 cycles, and then off for 55 (if you use 8bits of resolution).
You could then set the timer to match your mains frequency (50 or 60 hz), but you will not be in sync. I think that would cause more interference to other systems.
Re: AC Dimmer
Post by Pito » Mon Dec 11, 2017 5:15 pm
Afaik the MOC304(6,8)x devices include the zero switching detector, so you must not mess with a special circuit..
pokemon99
Re: AC Dimmer
Post by pokemon99 » Mon Dec 11, 2017 5:19 pm
MOC3023 without a zero detector.
So tnank you. The problem itself was not, the circuit works.
I wanted to know if there was an opportunity, run on two timers, that's all.
Re: AC Dimmer
Post by victor_pv » Mon Dec 11, 2017 6:22 pm
You can, the switching won't be synchronized with the AC wave, so no good for lighting, but for a heater you should be ok.
I do something similar for my reflow oven controller, and works fine, though I plan to enable zerocross detection now that I have a custom board for it.
pokemon99
Re: AC Dimmer
Post by pokemon99 » Mon Dec 11, 2017 6:32 pm
Thank you.
This is my project, I used to be without a web interface, now I'm expanding the functionality when there is time
http://62.80.175.55:85/
login:admin
pass:22222
Re: AC Dimmer
Post by RogerClark » Mon Dec 11, 2017 7:36 pm
Because the response time of a heater is so slow, you probably don’t need the zero crossing detector.
but It depends on the purpose of the system.
I built a system to use surplus solar electricity, and it was very important that the system did not use more power in each cycle ( actually each half cycle) than was available in the surplus
So tuning in a 4kW heater for 1 second and then off for 9 seconds to give 10% power usage was no good, because for those 9 seconds all the surplus power goes to waste, and in the first 1 second, the system needs to get 3.6kW from the grid.
Andy: I saw and example circuit that used a capacitor instead of resistors , but I am not sure how well it works.
There is even an Atmel application note where they connect the MCU GPIO directly to the mains via a very high value resistor.
I.e. It is possible to power the MCU via one of those capacitive power supplies , so that the whole circuit is not isolated from the mains, and you don’t need an opto at all, as you can drive the gate of the triad directly from the MCU ( assuming the MCU can deliver enough current from its GPIO, e.g. via paralleling a whole port of pins together and turning them all on or off at the same time using the BSSR reg)
And if control is via radio, the whole thing can be safely put in an isolated box.
However... it’s very hard to debug problems in this scenario, and if you get things wrong the MCU goes up in smoke very quickly
So it’s not an approach I have taken. But it is the approach used by those radio controlled inline mains sockets
pokemon99
Re: AC Dimmer
Post by pokemon99 » Mon Dec 11, 2017 8:17 pm
For power I use a switching power supply, everything is in a plastic box and only the encoder has a metal handle
I also met the circuit where a diode bridge and a mosfet are used, but I have never tried it
Re: AC Dimmer
Post by RogerClark » Mon Dec 11, 2017 8:20 pm
The remote controlled dimmers have a button on them, but it’s a piece of plastic which presses on a small button on the PCB.
I guess you could have an insulated “handle”
