RFM69HW demo application for blue pill?
Re: RFM69HW demo application for blue pill?
Post by mrburnette » Fri Dec 29, 2017 2:38 pm
turboscrew wrote:
Fri Dec 29, 2017 8:30 am
Yes. I've been thinking about the two other options: the LowPowerLab's and Hessling's. Both just seem to require quite a lot of work.
Take a look at this link: http://stm32duino.com/viewtopic.php?f=15&t=938#p10875
The RadioHead library may be a better option for you.
stevech indicates he has had success. PM him if you wish, but ask him to post to this thread so we do not loose his input.
Also, Adafruit has a version of the RadioHead lib up on github: https://github.com/adafruit/RadioHead with example code which may get you started easier.
// Example sketch showing how to create a simple addressed, reliable messaging client
// with the RHReliableDatagram class, using the RH_ASK driver to control a ASK radio.
// It is designed to work with the other example ask_reliable_datagram_server
// Tested on Arduino Mega, Duemilanova, Uno, Due, Teensy
turboscrew
Post by turboscrew » Fri Dec 29, 2017 3:36 pm
Thanks!
It seems that RadioHead is no more just a virtual wire it (mostly) used to be!
Have to take a better look...
