backports
backports
Post by zmemw16 » Fri Dec 29, 2017 5:53 pm
the debian linux sites have a backports repo, ok so maybe not quite correct.
so what if anything could be backported from say f4 to f1, f7 to f4 or f7 to f1 ?
maybe something above and beyond sdio/dma etc
something that could be commonized :-)
Re: backports
Post by mrburnette » Sun Dec 31, 2017 3:31 pm
Hmmmmm...
Well that is an interesting question.
Generally, evolution of code and support libraries are forward evolving as new h/w has new features but old peripherals must be dragged into the new architecture.
Going backwards with code designed from the ground-up for an advanced processor sounds like lots of work! :shock:
Likely the sensor/device that would benefit from the effort would just be supported better natively on the F4 with existing code. The exception would be a commercial implementation where the dekta-cost would become significant with quantity units.
Any examples?
Re: backports
Post by zmemw16 » Sun Dec 31, 2017 4:04 pm
suppose i rewrite it as thinking of 'some bleeding edge you could really, really use saving you masses of time.'
example sdio/spi/dma f4 to f1, i know i asked the question :-)
Re: backports
Post by stevestrong » Tue Jan 02, 2018 3:43 pm
We had some backports from F4 to F1 (see the SDIO lib).
But it is always difficult as you have to deal with different registers/hardware structure.
Re: backports
Post by zmemw16 » Tue Jan 02, 2018 4:15 pm
as i recall the surprise was not how bad/hard it was, but that it wasn't :D
srp
