Problems with STLink
Iguita
Post by Iguita » Wed Jan 03, 2018 1:06 pm
I've bought a cheap Chinese version of ST Link/V2 but having some problems to put it to work. I've installed latest STM drivers, got it under Universal Serial Bus device branch as STM32 STLink but it refuses to work. After checking of event's log I've found this:
Device USB\VID_0483&PID_3748\6&418b671&0&3 was not migrated due to partial or ambiguous match.
Last Device Instance Id: USB\VID_1C4F&PID_0034\6&271a58ce&0&3
Class Guid: {745A17A0-74D3-11D0-B6FE-00A0C90F57DA}
Location Path: PCIROOT(0)#PCI(1A00)#USBROOT(0)#USB(1)#USB(3)
Migration Rank: 0xF000FFFFFFFF0023
Present: false
Status: 0xC0000719
Windows 10 x64 1709
I couldn't find any solution for this and that is the reason why I had to ask for an advice on this place. Thanks in advance.
Re: Problems with STLink
Post by stevestrong » Wed Jan 03, 2018 3:21 pm
Iguita
Post by Iguita » Wed Jan 03, 2018 5:48 pm
Thank you for the answer, stevestrong. I didn't but I've previously understood that I can flash microcontroller, not from STM32 ST-LINK Utility but from STVP. I've updated device with your patch after that and it still says that "was not migrated due to partial or ambiguous match".
What could be the problem with ST-Link utility in my case?
Post by Pito » Wed Jan 03, 2018 5:56 pm
What about this - the latest, it seems
http://www.st.com/content/st_com/en/pro ... nk009.html
Post by dannyf » Wed Jan 03, 2018 5:59 pm
You have a vid/pid mismatch. 3748 vs 374B.
Post by zmemw16 » Thu Jan 04, 2018 1:48 pm
uh? i just plugged in my usb st/link block, blue/white already in
so lsub gives
Bus 003 Device 015: ID 0483:3748 STMicroelectronics ST-LINK/V2
Bus 003 Device 014: ID 04d8:fc92 Microchip Technology, Inc. Open Bench Logic Sniffer
Bus 003 Device 013: ID 0bda:2838 Realtek Semiconductor Corp. RTL2838 DVB-T
Bus 003 Device 012: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
Bus 003 Device 011: ID 0483:3748 STMicroelectronics ST-LINK/V2
Post by stevestrong » Thu Jan 04, 2018 3:10 pm
Missing infos:
- which core do you use (Arduino_STM32, STM32DUINO, or STM32GENERIC)?
- which board do you use?
- which IDE do you use? Arduino? Which version?
- What is STVP?
- if you can flash with STLink utility it means you have the right drivers installed, so it must be something wrong with the flashing utility of the used core. So go back and answer question 1. And post here the full message you get from Arduino IDE, if you use it.
- STLink DOES NOT WORK AS SERIAL PORT !!!
You have to connect a USB cable to the micro USB slot (blue pill) in order to have USB serial port.
Post by dannyf » Thu Jan 04, 2018 8:00 pm
it depends. some v1 and all v2 and newer ones support serial comm: https://dannyelectronics.wordpress.com/ ... link-v2-1/
stvp is a st standalone programmer.
Iguita
Post by Iguita » Thu Jan 04, 2018 8:14 pm
how to solve that?
Missing infos:
1. answered below
2. Blue Pill. Tried also with StM8 board
3, I've created some code from Arduino IDE but also from CxSTM32
- What is STVP?
STLink Visual Programmer
I am using hex file, not uploading code from Arduino IDE.
I didn't use it as serial port. Thank you for advice.
Post by stevestrong » Thu Jan 04, 2018 9:59 pm
OK, so it seems that you are not uploading with Arduinoi IDE.
As you may know, this forum is mainly dealing with Arduino for STM32.
If you use your own tool chain, you are on your own.
You could still get some help if you tell us more how exactly your toolchain does look like.
And maybe you give us some example files to reproduce your problem.
