nrf24 / esp8266 /xbee section ?
Re: nrf24 / esp8266 /xbee section ?
Post by zmemw16 » Wed Jan 17, 2018 3:53 pm
i thought as per topic aarrrhhh data logging from engine to remote sd in boot using nrf24. fiber glass body would just make it easier.
curious if you'd try it ?
WE HAVE HOT WATER
WE HAVE RADIATORS - no we DID HAVE. New soldered water boiler connection failed under testing, drain, solder, vent, repeat ?
BennehBoy
Post by BennehBoy » Tue Jan 23, 2018 4:20 pm
Ah yeah that's probably a reasonable use case for long term 'always on' logging.
https://github.com/BennehBoy
Post by zmemw16 » Tue Jan 23, 2018 4:39 pm
we still have hot water & heating
quietly impressed with hive thermostat control, not quite so much with user interface, but it's not too bad
according to web searches, it'll be ok until first battery change.
i've got an echo dot on order, curious on i'll how to control heating "hive" from it, i suspect i'll need the plus with a zigbee hub
if not then it's an expensive intercom. :D
Post by mrburnette » Tue Jan 23, 2018 9:51 pm
http://alexamods.com/guide-install-ask- ... exa-skill/ :o
Post by zmemw16 » Tue Jan 23, 2018 10:09 pm
interesting link, will look at it
i surrendered to an echo plus
it supposedly has a zigbee hub built-in
so maybe i can eavesdrop on the network traffic
magic word was zigbee
