[SOLVED] Need Help with EEPROM Emulation
Re: Need Help with EEPROM Emulation
Post by Pito » Sun Jan 14, 2018 11:04 am
Run the sketch with writing to the EEPROM address 0 and then power it off, and then READ the memory with the STLink. You should see 0 there, I would guess. Then PROGRAM the sketch with writing to the EEPROM commented out, and then READ it with the STLink. You will see FF there most probably.
alexandros
Post by alexandros » Tue Jan 16, 2018 7:11 am
OK now i am very confused , Pito is that possible? , So can i use it to store some data or not? :(
Is it storing values as long as the program is alive? i dont get it, is there any other way except putting an eeprom external chip?
Post by victor_pv » Wed Jan 17, 2018 7:51 pm
As pointed out before, the problem is most likely that you are wiping the whole flash when uploading with St-Link.
You must use a method that doesn't wipe the whole flash (you can do so if using the ST_link GUI tool, has an option to select whether you want to completely erase the mcu or only the required pages). Our bootloader also only clear individual pages.
The ROM serial bootloader, as st-link can do it either way, you have to use the GUI to select what you want to do.
alexandros
Re: [SOLVED] Need Help with EEPROM Emulation
Post by alexandros » Wed Jan 17, 2018 8:39 pm
Thanks for your replies guys
Actually i made it work.
When i used This
			EEPROM.PageBase0 = 0x801F000;
			EEPROM.PageBase1 = 0x801F800;
			EEPROM.PageSize  = 0x800;
Instead of this
			EEPROM.PageSize  = 0x400;
