BluePill Software Serial Library
gproduct
Post by gproduct » Fri Feb 02, 2018 4:01 am
Hi!
Has anyone found a good Software Serial library for the STM32 on Arduino? (I'm using a Bluepill)
Cheers!
zoomx
Re: BluePill Software Serial Library
Post by zoomx » Fri Feb 02, 2018 7:45 am
BluePill has 3 hardware serial but there is also this software serial
viewtopic.php?t=864
and this
viewtopic.php?t=6
gproduct
Post by gproduct » Fri Feb 02, 2018 8:51 am
Thannks a lot!
asmallri
Post by asmallri » Tue Feb 06, 2018 2:32 am
If you skip to the last post of each referenced link you will see that currently neither method works
Post by Rick Kimball » Tue Feb 06, 2018 3:21 am
The code I tested (viewtopic.php?f=13&t=6&start=40#p21156") works just fine. The key is not trying to handle read data as quickly as it becomes available so that the buffers don't overflow and the interrupts aren't blocked.
You (asmallri) are using delays while you are reading, I'm guessing this is a problem. You might try making your logic less dependent on delay() type code and make it more event driven.
