Qemu or other emulators
ajk
Post by ajk » Wed Feb 07, 2018 4:59 am
For all you Arduino + STM32 pros, do you normally develop directly on a board or do you use an emulator like Qemu?
I feel like I spend a lot of time getting my blue pills programmed (wire it up to my ftdi board, switch jumper, apply power, program, wait impatiently, test). I'm thinking there must be a more efficient path.
Re: Qemu or other emulators
Post by ag123 » Wed Feb 07, 2018 5:28 am
actually i used this, that has qemu as part of it
https://gnu-mcu-eclipse.github.io/
nevertheless qemu can't simulate everything or more correctly there's lots more development needed to emulate a stm32 m3
but it works for really basic scenarios like blinking a led, beyond that u may need to develop the qemu itself
in the end i simply test with a maple mini, 'not efficient', but i'd get to test it real
oh and if you have the bootloader https://github.com/rogerclarkmelbourne/ ... bootloader
properly installed on the Bluepill / maple mini normally the command dfu-util -a n -D sketch.bin does the sketcch install over usb
and in the arduino ide it is simply clicking a button
ChrisMicro
Post by ChrisMicro » Wed Feb 07, 2018 9:23 am
If you are using Linux you could try to develop your software on the PC.
I started an emulation framework here.
