[SOLVED] How to change pwmWrite freq?
ismail.cal
Re: Solved: How to change pwmWrite freq?
Post by ismail.cal » Wed Mar 02, 2016 12:33 pm
How do we want to produce up to 100 kHz with maple . How do I need PWM frequency calculations
Post by RogerClark » Wed Mar 02, 2016 9:23 pm
@ismail.cal
Don't cross post.
Several people have replied to your other thread.
I will remove your posting to this thread as its unnecessary
DaveCalaway
Re: How to change pwmWrite freq?
Post by DaveCalaway » Sun Jan 29, 2017 2:36 pm
melodic wrote:Solved.
HardwareTimer pwmtimer(2);
//    pinMode(11, INPUT_ANALOG);
//    Serial.begin(115200);
    pinMode(PA1, PWM);
    pwmtimer.setPrescaleFactor(1);
    pwmtimer.setPeriod(50);
Hi guys, i tried this code but nothing works.
HardwareTimer timer(2);
   // set up pin 9 for PWM
       pinMode(9, PWM);
    // The frequency of the PWM signal (i.e., the frequency of a complete on/off cycle) on the Arduino is approximately 490 Hz.
    // On the Maple, the frequency is configurable, defaulting to about 1100 Hz, or 1.1 KHz.
      timer.setPeriod(2041); // 2041 microsecond = 0,0020408 second = 1/490Hz
    // void pwmWrite(uint8 pin, uint16 duty_cycle)
    pwmWrite(9,50000);  // Maple duty_cycle = 0-65,535
what's wrong?
fari
Post by fari » Fri Sep 08, 2017 8:22 pm
Hi Dave!
You code does not work, because you pwmWrite is in the loop and it is permanently overwriting the signal.
Here is a code which work
#define PWM_OUT PA8 //PWM output
#define PWM_OUT_COMP PB13 //complementary output
void setup(){
// initialize digital pin PC13 as an output.
pinMode(PC13, OUTPUT);
HardwareTimer timer1 = HardwareTimer(1);
timer1.setPrescaleFactor(1);
timer1.setPeriod(2041); //490
//timer1.setPeriod(10); //100kHz
pinMode(PWM_OUT, PWM); //Ideally these would be done as bit wise as I dont know exactly whats being set here..
pinMode(PWM_OUT_COMP, PWM);
timer_dev *t = TIMER1; //refers t to Timer 8 memory location, how to read back?
timer_reg_map r = t->regs;
bitSet(r.adv->CCER,0); //this should enable complimentary outputs
bitSet(r.adv->CCER,2);
pwmWrite(PWM_OUT, 10); //
void loop(){
// I am alive
digitalWrite(PC13, HIGH); // turn the LED on (HIGH is the voltage level)
//digitalWrite(PA5, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(PC13, LOW); // turn the LED off by making the voltage LOW
//digitalWrite(PA5, LOW); // turn the LED off by making the voltage LOW
