Dhrystone and Whetstone Benchmarks for STM32F103
Re: Dhrystone and Whetstone Benchmarks for STM32F103
Post by Pito » Sat Jan 07, 2017 8:21 pm
Thanks done! :)
103ZET6 running in flash.
Starting Whetstone benchmark...
Loops: 1000Iterations: 1Duration: 20366 millisec.
C Converted Double Precision Whetstones: 4.91 MIPS <<< 72MHz
Loops: 1000Iterations: 1Duration: 15250 millisec.
C Converted Double Precision Whetstones: 6.56 MIPS <<< 96MHz
Loops: 1000Iterations: 1Duration: 12201 millisec.
C Converted Double Precision Whetstones: 8.20 MIPS <<< 120MHz
Loops: 1000Iterations: 1Duration: 11438 millisec.
C Converted Double Precision Whetstones: 8.74 MIPS <<< 128MHz
Dhrystone Benchmark, Version 2.1 (Language: C) <<< 128MHz
Execution starts, 300000 runs through Dhrystone
Execution ends
Microseconds for one run through Dhrystone: 7.28
Dhrystones per Second: 137397.93
VAX MIPS rating = 78.20
Post by Pito » Sun Jan 08, 2017 1:56 pm
F103ZET6 (BlueZEX board) at 128MHz CPU, Dhrystone running off the 512kB EXRAM (10ns SRAM settings D1, A0):
Execution ends
Microseconds for one run through Dhrystone: 57.35
Dhrystones per Second: 17437.22
VAX MIPS rating = 9.92
Post by Pito » Wed Apr 12, 2017 7:37 pm
Black F407ZET6 board at 168MHz:
Whetstone
Loops: 1000Iterations: 1Duration: 6251 millisec.
C Converted Double Precision Whetstones: 16.00 MIPS
Dhrystone
Execution starts, 3000000 runs through Dhrystone
Execution ends
Microseconds for one run through Dhrystone: 3.58
Dhrystones per Second: 279445.78
VAX MIPS rating = 159.05
Post by ag123 » Tue Apr 18, 2017 10:41 am
i finally got my dhrystone compiled, this is on the black stm32f407vet6 variant that's currently work-in-progress
note that i'm using -O2 optimization and on arm-gcc 6
Execution ends
Microseconds for one run through Dhrystone: 2.46
Dhrystones per Second: 407225.93
VAX MIPS rating = 231.77
i made the sketch wait for the key 'g' on usb serial to start running. i.e. press 'g' to start
wow 231 mips, that seem to beat even st's specs of 210 DMIPS, i'm not sure if gcc optimised away (i.e. removed) some codes :lol:
http://www.st.com/en/microcontrollers/stm32f407ve.html
based on the results here;
http://www.roylongbottom.org.uk/dhrystone%20results.htm
it would seem that the f407 is pretty much on par with those old pentium 1 computers
                      Dhry1  Dhry1  Dhry2  Dhry2
                        Opt  NoOpt    Opt  NoOpt
                        VAX    VAX    VAX    VAX
CPU              MHz   MIPS   MIPS   MIPS   MIPS
AMD 80386         40   17.5   4.32   13.7   4.53
IBM 486D2         50   26.6   7.89   22.4   7.89
80486 DX2         66   45.1   12.0   35.3   12.4
Pentium          133    239   38.3    181   39.0
Pentium          166    270   43.6    189   43.9
Pentium          200    353   47.4    269   48.1
Pentium MMX      200    352   51.4    276   51.0
dhry21a_usbserial.zip
dhrystone benchmark on usb-serial outputs
(9.44 KiB) Downloaded 5 times
martinayotte
Post by martinayotte » Tue Apr 18, 2017 1:18 pm
Something looks strange : I've done tests on Sep 2015 (look at page 4 on current thread), and F405 was giving 130 MIPS.
Did you overclocked your F407 ?
Post by ag123 » Tue Apr 18, 2017 1:23 pm
nope i'm working on the development branch of the f4 libmaple on steve's repository
https://github.com/stevstrong/Arduino_S ... F4_variant
currently F_CPU=168000000L
i've not really examine the clock setting codes literally and i'm not too sure if even this setting could have resulted in the f4 actually running at a higher speed than stock maximum
the few things that i'm doing are compiling with -O2, turning off all debug settings
and i'm using the arm gcc toolchain 6-2017-q1-update February 23, 2017
https://developer.arm.com/open-source/g ... /downloads
but i've read on a separate boinc forum that gcc optimizations could actually remove code sections that are not referenced, i'm not too sure if -O2 or some sort could have removed those codes
e.g. if there is a statement c = a + b and that c is not referenced, gcc could literally remove that statement while doing the compiles
i just repeated the compile with -O0 - no optimization
Execution ends
Microseconds for one run through Dhrystone: 10.16
Dhrystones per Second: 98448.63
VAX MIPS rating = 56.03
repeat the -O2 compile again
Execution ends
Dhrystones per Second: 407308.80
VAX MIPS rating = 231.82
hence the -O2 flag made the difference
note that the default optimization in platforms.txt is -Os optimise for size
compile with -Os, no debug
Execution ends
Microseconds for one run through Dhrystone: 3.70
Dhrystones per Second: 270038.23
VAX MIPS rating = 153.69
i'd think these optimizations may cause various problems for timing sensitive codes as gcc may do things ilke unrolling loops etc
Post by Pito » Tue Apr 18, 2017 2:49 pm
With 9-2023-q2-update May 14, 2023 we will get 521.21 VAXMIPS.
:lol:
Post by ag123 » Tue Apr 18, 2017 2:57 pm
it may be exponential, by then it could be infinity mips, gcc deem that all those codes are not needed and remove it :lol:
Post by victor_pv » Tue Apr 18, 2017 3:47 pm
ag123 wrote:it may be exponential, by then it could be infinity mips, gcc deem that all those codes are not needed and remove it :lol:
Did you check whats the optimization set on the F1 core? if you use the same it will be more comparing apples to apples, would be a better reference vs the F1
Post by stevestrong » Tue Apr 18, 2017 4:17 pm
On F1 the default optimization is "Os". This gives the shortest size and still good speed.
It would be interesting to see the result using "O3".
Who is online
