Dhrystone and Whetstone Benchmarks for STM32F103
Re: Dhrystone and Whetstone Benchmarks for STM32F103
Post by ag123 » Sun Apr 23, 2017 5:28 pm
try Serial instead of SerialUSB (note, i couldn't get Serial to work, hence i basically used SerialUSB :P )
i've read somewhere that USB needs to keep checking the host for messages, i'd guess that may be a lot of *interrupts* and hence slower (with SerialUSB), just a guess :D
Post by Pito » Sun Apr 23, 2017 5:37 pm
Splitting the source file into three is ABSOLUTELY ESSENTIAL !!!
I messed yesterday solving following issue:
1. in CMSIS DSP FFT example I generated 3 sinus tones with diff freqs and ampls
2. in a loop I sum up 3 sins to get the signal
3. while I worked with 1 file, it accepted only 1 (one) sinf in the loop, and that with special care on params - adding another sinf/cosf or any other math function crashed
4. I messed with it all day yesterday, debugging crashed almost randomly in rcc (!!!)
5. then I split it in 3 files (ino, h, cpp) and it works without any issue with absolutely everything I put inside.
Post by Pito » Mon Apr 24, 2017 11:01 am
-O0, -g, eabi-4.8.3-2014q1, new victor's "Generic STM32F4V Series", HardFPU w/ hard calls, 240MHz clock, Black 407ZET, SerialUSB, ag123's Whetstone:
Beginning Whetstone benchmark at 240 MHz ...
Loops:1000, Iterations:10, Duration:13510.15 millisec
C Converted Single Precision Whetstones:74.02 mflops
-Os, -g, eabi-4.8.3-2014q1, new victor's "Generic STM32F4V Series", HardFPU w/ hard calls, 240MHz clock, Black 407ZET, SerialUSB, ag123's Whetstone:
Loops:1000, Iterations:10, Duration:6010.35 millisec
C Converted Single Precision Whetstones:166.38 mflops
-O3, -g, eabi-4.8.3-2014q1, new victor's "Generic STM32F4V Series", HardFPU w/ hard calls, 240MHz clock, Black 407ZET, SerialUSB, ag123's Whetstone:
Loops:1000, Iterations:10, Duration:2141.57 millisec
C Converted Single Precision Whetstones:466.95 mflops
PS: the Double Precision results were 23 -Os, 38 -O3 ..
Post by ag123 » Mon Apr 24, 2017 8:12 pm
my guess is that those 500mflops benchmarks is always an eyebrow raiser, either way this benchmark is basically *fun* and it is the combined 'power' of a too 'smart' gcc -O3 and ART accelerator :lol:
monsonite
Post by monsonite » Fri Sep 22, 2017 8:00 pm
Hi All,
A little late to the party, but now testing 80MHz STM32L433 which is now available on the Arduino IDE.
Microseconds for one run through Dhrystone: 9.00
Dhrystones per Second: 111163.81
VAX MIPS rating = 63.27
You can find the board core for this STM32 here and here
https://github.com/GrumpyOldPizza/arduino-STM32L4
https://github.com/millerresearch/arduino-mystorm
We use the STM32L433 as a suport chip for our open source ICE40 FPGA board - BlackIce
mystorm.uk
Cheers
Ken
ChrisMicro
Post by ChrisMicro » Sat Sep 23, 2017 4:10 am
This one?:
https://www.fpgarelated.com/thread/799/ ... -dev-board
Its written: ICE40HX4K and an STM32F103 Cortex M3
Post by dannyf » Sat Sep 23, 2017 9:09 pm
I didn't see your code but in general, the use of arduino timing function millis() for benchmarking can lead to significant errors -> the standard code under-estimates time elapsed.
It is better to use systick, or dwt.
You can borrow the systick / dwt (coreticks()) code here: https://dannyelectronics.wordpress.com/ ... k-on-mcus/
I also wrote extensively about dhrystone / whetstone performance across multitudes of mcus. they are generally in line with what one would expect, with two exceptions:
1. PIC24 is exceptional in integer performance;
2. MSP432 is terrible in integer math with TI's own compiler.
Post by Pito » Sat Sep 23, 2017 10:00 pm
Do you have an evidence of such failing of millis() to support the statement?
Post by victor_pv » Sat Sep 23, 2017 11:34 pm
This one?:
I suspect it may be a new version of the board, since he called it BlackIce, and the one in the link is ICE40.
Post by dannyf » Sun Sep 24, 2017 1:05 am
it was pointed out to me that I actually didn't provide the whetstone benchmark code there -> since corrected, :)
The usage is quite simple:
#include "dhry.h"  //use dhrystone benchmark
#include "whetstone.h" //use whetstone benchmark
  time0=time_now(); //time stamp time0. time_now() is whatever timing function you prefer. For short duration execution, don't use the stock millis()
  //put your benchmark here
  dhrystone(); //dhrystone benchmark, or
  whetstone(); //whetstone benchmark
  time1=time_now() - time0; //calcualte time elapsed
The dhrystone() benchmark comes in three pieces, by design, to prevent the loops being optimized away.
Hope it helps.
You may wish to check out an earlier post: https://dannyelectronics.wordpress.com/ ... hry-stone/
if all you want to do is number crunching, even the low end PIC32s will do very well.
