STM32F103C8T6 extreme low power consumption (frequency, periphery)
marti159
Post by marti159 » Wed Jun 08, 2016 3:13 pm
Hi I need to make STM32F103C8T6-based device which run on 2x AA battery (3V).
Device will be counting pulses on digital input pin (about 1-10 pulses each minute).
Device will send status each minute over 443MHz radio:
I need *maximum* possible battery life.
STM32F103C8T6 will sleep all time. Pulse input will be on interrupt pin and wake up stm. After that stm go to sleep again.
Arduino ATmega328 has in datasheet:
Power Consumption at 1MHz, 1.8V, 25°C
̶ Active Mode: 0.2mA
̶ Power-down Mode: 0.1µA
̶ Power-save Mode: 0.75µA (Including 32kHz RTC)
How is it on STM32F103C8T6? Lower frequency = lower power consumption?
How can I decrease frequency? Now I have blue pill with 8.0MHz crystal and ticks at 72MHz. Is possible to set frequency to for example 2 or 8 MHz instead of 72MHz? Can I use 8MHz crystal an reduce frequency in software like fuses on Atmel AVR? Is there any minimal frequency?
Is possible to disable peripheries like UART, I2C, ... to decrease power consumption?
I found only:
#define CYCLES_PER_MICROSECOND    72
#define SYSTICK_RELOAD_VAL     (F_CPU/1000) - 1 /* takes a cycle to reload */
at file STM32F1/variants/generic_stm32f103c/board/board.h
Thank you for help and sorry for my bad English.
Re: STM32F103C8T6 extreme low power consumption (frequency, periphery)
Post by mrburnette » Wed Jun 08, 2016 3:23 pm
Please read this post: http://www.stm32duino.com/viewtopic.php?t=298
In addition, grab the STM32 Reference Manual - use Google to search for it. Read about the power domains in the chip. There are also Application Notes about power savings by chip architecture - again use Google.
Post by RogerClark » Wed Jun 08, 2016 9:30 pm
Like Ray says..
You will need to read the manual for the chip.
You can change the PLL multiplier, to a lower value, but I dont know off the top of my head what the lowest multipler is.
There is also a 2 x prescaler on the clock, so I suspect the minimum frequency would may be 8Mhz / 2, assuming there is a x1 Pll multiplier setting ( you need to check the manual)
But if you change the master clock freq, all the timings in the core will be wrecked.
e.g. UART timings will be wrong, Systick e.g. millis will be wrong, delay() will be wrong etc etc
Post by ahull » Wed Jun 08, 2016 11:38 pm
marti159 wrote: How is it on STM32F103C8T6? Lower frequency = lower power consumption?
Be aware that lowering the clock frequency may not save as much power as you might think. The reason for this is that if you perform a particular task at regular intervals, then performing that task quickly and then sleeping may use the same amount of energy as performing the task slowly and then sleeping. In fact, in many cases you actually perform things more efficiently if you run the processor faster and sleep longer, as you then have the advantage of leaving peripherals and external circuitry (your radio for example) on for shorter periods than you would if you performed the task slowly.
You will need to think carefully about this, and it may only be by experimentation that you determine the best regime for maximum battery life for your particular use case.
... Is there any minimal frequency? ...
In theory you can run from the 32kHz watch crystal if fitted, or the internal 32kHz R/C source.
These may be too slow to allow you to transmit your data however.
I suspect that with care, you can run the blue pill at 72MHz, and, if only waking up for a few mS every event, and with events only occurring up to 10 times per minute, I would suggest that a relatively modest battery will last almost as long as its self discharge rate, i.e. several years.
In my experiments, I managed to get results that suggested a single 18650 LiPo (around 2000mAh) would last for several years, so long as the STM32F103 completed its task quickly and therefore slept as much as possible. As it happens, the on board power LED was consuming a significant amount of power in my experiments, and removing it would be a serious suggestion, assuming your soldering fu is up to the task.
You may find my Sunrise and Sunset timer project of interest as it also contains some insights into the use of the low power modes of the STM
http://www.stm32duino.com/viewtopic.php?f=19&t=380
zoomx
Post by zoomx » Thu Jun 09, 2016 7:27 am
I am not sure but I read that a short fast burst and longer sleep is not better for batteries. It seems that batteries (maybe not all type of batteries) prefer to have a bit longer operations but at a lower mA that a short burst at high mA.
But I never made an experiment nor I read about a similar experiment. Maybe it is only an opinion.
@marti159
usually boards are not designed for low power operation and you must design your board or you have to modify common boards. The only low power boards that I saw are the TI Launchpad (various models) and some specialised Arduino board.
marti159
Post by marti159 » Thu Jun 09, 2016 8:07 am
I found STM32CubeMX software, that can calculate power consumption with enabled peripheries. Screenshots of stm32cubemx.
If I generate some C code in STM32CubeMX how can I use it in "Arduino STM32"?
At this topis in this forum is Arduino code with STM C:
#include <stdint.h>
#include <libmaple/pwr.h>
#include <libmaple/scb.h>
#define BOARD_LED_PIN 33
#define BOARD_BUTTON_PIN 32
#define BUTTON_DEBOUNCE_DELAY 1
// These are possibly defined somewhere but I couldn't find them. System Control Register
#define SCB_SCR_SLEEPDEEP 4       // Controls deepsleep(1) or sleep(0)
#define SCB_SCR_SLEEPONEXIT 2     // Controls sleeponexit (not used here)
volatile bool ledState = LOW;    // Used in ISR blinkState()
  //SerialUSB.println("HI!");  delay(100);    // Only works on first iteration, before stop mode
  // Clear PDDS and LPDS bits
  PWR_BASE->CR &= PWR_CR_LPDS | PWR_CR_PDDS;
  // set sleepdeep in the system control register
  SCB_BASE->SCR |= SCB_SCR_SLEEPDEEP;
  // Now go into stop mode, wake up on interrupt
  asm("    wfi");
  digitalWrite(BOARD_LED_PIN, ledState);
  togglePin(3);
Is possbile to use STM C in Arduino code? How? Is there any rules?
Is there any language reference for "arduino stm" as for "arduino avr"?
Post by mrburnette » Thu Jun 09, 2016 11:52 am
zoomx wrote:I am not sure but I read that a short fast burst and longer sleep is not better for batteries. It seems that batteries (maybe not all type of batteries) prefer to have a bit longer operations but at a lower mA that a short burst at high mA.
I suspect that the internal Z of the battery and the chemistry would determine the best methodology - but, using a supercap essentially changes the equation significantly. A fully charged supercap across a new battery provides the ability to maintain low Z while essentially neglecting the internal Z of the battery; assuming the power consumption pulse is shorter than the RC constant of the battery + supercap.
The old 'mercury button cells' had long life but were rated only for a minuscule current draw. Replacement alkaline and silver (primary) chemistry have very different discharge curves.
Post by ahull » Fri Jun 10, 2016 9:59 am
There is a lot of good information regarding battery life and microcontrollers, but there is also quite a lot of dross (advertising for the latest fantoosh version of the big boy silicon players latest iteration of their take on low power microcontrollers using their in house magic sauce mainly).
This might whet your appetite, however for most small projects, it is fairly easy to set up your multimeter to watch the current being fed to the board(s) and get a reasonable ball park figure.
keypunch
Post by keypunch » Fri Apr 07, 2017 7:28 am
Interesting, insightful, thought/comments, and points for this thread of discussion.
What I am tring to find at moment is what sort of cable, jig or such one uses to measure the current and voltage? I have a sense a jig is what is likely needed. I suspect there are as many different ways to design a jig as are projects.
I am still trying to find out if makes sense to connect a battery to a pin directly or power via the USB. Many have commented the voltage regulators of many MCUs have low insertion related losses. So far the research reading I have done on this seems to have some mixed opinions. This would suggest to me additional tests to find out the current/battery profiles the MCU has in context of the complete solution. Perhaps compare direct vs via the regulator vs the pros/cons of.
I tend to find out the real world results and have the data for. Using the datasheets and prior research/projects as starting point of design. Sometimes there is a refinement/learning process that unfolds to improve design one feels or sees as issues. Sometimes one finds out prior experience gained means one was close or as close as can be. The other sometimes is just a varied combination of many factors.
Regards,
John L. Males
Toronto, Ontario
Canada
07 April 2017 03:28 EDT
Post by ag123 » Fri Jun 02, 2017 8:29 am
there are also various 'lipo fuel gauges' and coulomb counters which might be useful if one is looking out for a 'battery meter'
http://www.ebay.com/sch/i.html?_from=R4 ... o&_sacat=0
https://learn.sparkfun.com/tutorials/lt ... okup-guide
often running on 'low power' isn't simply about the mcu, the peripherals consume power too, hence, it'd be necessary to try to limit the peripherals power draw, e.g. turn off clocks for peripherals not in use.
then there is that *huge battery consuming* **systick counter*, it would keep the device awake each tick every milliseconds
disable the systick interrupt if it isn't needed
systick_disable();
, note that disabling systick stops the system uptime counter
http://www.stm32duino.com/viewtopic.php ... =10#p28608
and *disable/disconnect usb* if you don't need it usb has a start of frame interrupt every millisecond
once you get rid of all the interrupts, you could basically "WFI" to wait for the interrupt and save battery
i think there is even 'sleep on exit' techniques where the interrupt handler runs and mcu goes back to sleep once the interrupt handler completes. but i'd guess to save battery 1'd need to keep interrupts to an absolute minimum.
to go further one could run with lower cpu clocks e.g. 48mhz instead of 72mhz
actually chatty wireless devices is a big battery drain, energy is simply being radiated away or converted into heat in the circuits, hence reducing those polling / transmit frequency would probably help. it would therefore mean being able to shut-down the radio transceiver when not in use
note that BLE beacons has been known to run on coin cell batteries for months
https://en.wikipedia.org/wiki/Bluetooth ... rgy_beacon
https://kontakt.io/blog/extensive-guide ... h-beacons/
there are lots of those 'BLE' locators on ebay it is a pity that the current blue pills / maple minis or even from stm itself don't have one that integrates a bluetooth radio natively
http://www.ebay.com/sch/i.html?_odkw=bl ... r&_sacat=0
