IceStamp FPGA in DIL28 and UPduino in DIL32
Post by Pito » Tue Oct 24, 2017 9:27 am
This is a prototype we have got a chance to play with:
1. built around Lattice ICE40LP384, 384 cells, 21 IOs
2. DIL28 socket, single 3.3V power
3. the FPGA bitstream loads from the on-board flash, or from an MCU, ie. stm32, etc.
4. flash programming for example via the cheapo "usbasp" programmer (modded fw, free), or an FT232H, etc.
5. FPGA development (verilog, vhdl) in Lattice's IceCube2 or in IceStorm (both free)
martinayotte
Re: IceStamp FPGA Board in DIL28
Post by martinayotte » Tue Oct 24, 2017 3:40 pm
There is also this one :
http://gnarlygrey.atspace.cc/development-platform.html
I've purchased 2 of them recently and played a bit with it.
ChrisMicro
Post by ChrisMicro » Tue Oct 24, 2017 4:07 pm
Do they really cost only 7.99$ for
5.3K LUTs, 1Mb SPRAM, 120Kb DPRAM, 8 Multipliers ?
That is ways better than the 384 cells of the other board.
5.3K LUTs could even be sufficient for a small MC, I think.
Just4Fun
Post by Just4Fun » Tue Oct 24, 2017 4:58 pm
For that price you can get only the FPGA chip (from Digikey) :shock:
martinayotte
Post by martinayotte » Tue Oct 24, 2017 8:13 pm
The guy who produce UPDuino boards probably got a good discount for its chip, because he is really selling those at $7.99 free shipping, I've purchased 2 boards, and got them by regular post envelop within a week, USA to Canada.
Re: IceStamp FPGA in DIL28 and UPduino in DIL32
Post by Pito » Mon Nov 06, 2017 8:10 pm
http://www.latticesemi.com/en/Products/ ... Board.aspx
Lattice supplied the chips, I would guess :)
The UPduino board is of great size - DIL32, interestingly the pcb is almost transparent (as it lacks any solid ground plane, not easy to do in such format with only 2 layers). SPI flash and a voltage regulator at the bottom side. It calls for 4 layers, sure.
These chips are (ultra) low power, but quite fast (40nm technology, the smaller one runs here 320MHz internally) so a good grounding could be necessary..
martinayotte
Post by martinayotte » Wed Nov 08, 2017 2:49 pm
Until now, I didn't faced any issue about grounding, even using it with 20cm dupont wires.
I've been able to port some simple old project done in the past on Altera or Xilinx, a I2C Slave controlling 3 PWM output to the RGB Led, overall using only 10% of the LUT. Considering that this chip has already some HW I2C builtin, which I didn't use, maybe I should redo the project using them to drop usage below 5%.
Post by Rick Kimball » Wed Nov 08, 2017 3:32 pm
@martinayotte have you tried out LatticeMico32 on that board? If so, how much of the chip does it use?
Post by Pito » Wed Nov 08, 2017 3:58 pm
to the RGB Led
@Martin: I've been blinded by your RGB demo (from eevblog) running just now in front of me.. 8-)
Grounding/gnd_planes: is important because of signal integrity issues, quite common with fpga designs.. The IceXX chips support ie LVCMOS 3.3/2.5/1.8/1.2V, diff signalling - LVDS25E, subLVDS with input speeds~500Mbit/s. Thus the signal integrity is important.
martinayotte
Post by martinayotte » Thu Nov 09, 2017 9:59 pm
I know a bit about LatticeMico32 as I've look at while ago to see if it could be ported to Xilinx or Altera.
I'm really not sure how much LUTs it will take and if it will even fit in those tiny UPDuino ...
I'm busy these days, but maybe I will try when I will get a chance !
