IceStamp FPGA in DIL28 and UPduino in DIL32
martinayotte
Re: IceStamp FPGA in DIL28 and UPduino in DIL32
Post by martinayotte » Thu Nov 09, 2017 10:04 pm
Pito wrote:
Wed Nov 08, 2017 3:58 pm
@Martin: I've been blinded by your RGB demo (from eevblog) running just now in front of me.. 8-)
The RGB demo I've posted on EEVBlog is only gnarlygrey example modified to have a FSM with 8 colors, it has nothing with the one I've mentioned above with 3x 8bits PWM controlled by I2C slave, which can then fadein/fadeout over million of colors ... ;)
Post by Pito » Fri Nov 10, 2017 10:37 pm
The Zylin's ZPU example (but with ~half bram size than the HX8K set in source, needs some fine tuning) fits easily into UPduino
Logic Resource Utilization:
    Total Logic Cells: 2249/5280
        Combinational Logic Cells: 1558     out of   5280      29.5076%
        Sequential Logic Cells:    691      out of   5280      13.0871%
        Logic Tiles:               349      out of   660       52.8788%
    Registers:
        Logic Registers:           691      out of   5280      13.0871%
        IO Registers:              0        out of   480       0
    Block RAMs:                    16       out of   30        53.3333%
The UP5k has got 15kB bram, the HX8k 16kB bram. UP5k needs to decode the 0..15kB bram region somehow.. :)
Post by Rick Kimball » Sat Nov 11, 2017 3:51 pm
That looks interesting however it seems like development on it has stalled. Is there someplace that talks about that softcore. Everything I found seems to have cooled off in 2015.
martinayotte
Post by martinayotte » Sat Nov 11, 2017 4:19 pm
Indeed, interesting !
Especially that I have already played with original AlvieBoy's ZPUino on Xilinx.
Post by Pito » Sun Nov 12, 2017 1:22 pm
I think that is the tendency nowadays. You can hardly design a better performing sw MCU inside any fpga than are the cheapest hw off-the-shelf offerings today. The designs are therefore either retro computing exercises, or more-less for educational purposes. If you need a sw MCU within your fpga design all those are considered mature. The fpga vendors published their soft MCUs 10y back in average. Moreover, as an improvement, they started to place hw MCUs inside their fpga fabric..
Re: IceStamp FPGA Board in DIL28
Post by Rick Kimball » Fri Nov 17, 2017 9:43 pm
martinayotte wrote:
Tue Oct 24, 2017 3:40 pm
There is also this one :
http://gnarlygrey.atspace.cc/development-platform.html
Mine just showed up in a plain white envelope .. You can see the holes in the plastic bag where the mail sorter machinary squished it .. * crosses fingers and solders on the pins : )
Post by zmemw16 » Fri Nov 17, 2017 10:17 pm
yep, white envelope, single wrap of thinnish bubble wrap.
both appear ok.
rather prompt as i was expecting aliexpress travel rates. :)
srp
Post by Pito » Sun Nov 19, 2017 1:10 pm
Swapforth J1a running on UPduino @ 40MHz, 460k uart, teraterm terminal, built under IceCube2:
Device Utilization Summary
    LogicCells                  :	1153/5280
    PLBs                        :	220/660
    BRAMs                       :	16/30
    IOs and GBIOs               :	24/36
    PLLs                        :	1/1
words .EASTER EASTER N E D Z X C G Y ORIF ANDIF fib2-bench fib2 FACS FAC .FAC SETUP *BUFF LAST F-BUFF MAX-DIGITS dump
see _ .xt | new leds ms marker convert restore-input save-input hex endcase endof of case s" _ [compile] find .( within erase
pad unused abort" ." mod / /mod word move u.r .r u. . d. d.r #> #s # sign hold <# hld BUF BUF0 spaces */ */mod fm/mod sm/rem
sgn constant variable create >body repeat while else ( [char] ['] pick roll init .s tasksel quit evaluate refill accept char postpone
literal ' abort chars char+ cells r@ r> >r depth io@ nip over drop dup swap u< < = invert or and xor - + 2/ 2* decimal unloop j i
+loop loop ?do leave do recurse does> until again then begin if ahead ; exit :noname : [ ] immediate sliteral s, compile, c, ,
allot parse parse-name \ source 2! 2@ cmove> cmove fill >number sfind align um/mod m* * um* d2* d0= m+ s>d dabs dnegate
d+ aligned /string here abs words forth tth >in state base type bounds count c! c@ max min 2over 2swap +! 2dup ?dup 2drop
tuck -rot rot true false @ execute .x .x2 bl cr space emit key key? rshift lshift io! ! u> 0> 0< > 0<> <> cell+ 0= 1- negate 1+  ok
  ok
unused . 2256  ok
  ok
Fib2(10000) benchmark @40MHz (https://theultimatebenchmark.org/):
: fib2 0 1 rot 0 do over + swap loop drop ;
: fib2-bench 10000 0 do i fib2 drop loop ;
fib2-bench  ok
  ok
17secs.
: collatz-folge-bench-10
  10 0 do 32101 cmax . loop ;
collatz-folge-bench-10 126 126 126 126 126 126 126 126 126 126  ok
  ok
215secs.
Post by Pito » Thu Nov 30, 2017 9:01 am
Mecrisp-Ice (an enhanced hw version of j1a and enhanced sw version of swapforth/mecrisp-forth) on UPduino, with 12kB of ram and load/save to an external flash.
http://mecrisp.sourceforge.net/
Mecrisp-Ice 1.0
here . 5892  ok.
  ok.
unused . 6396  ok.
  ok.
words FACS FAC .FAC SETUP *BUFF LAST F-BUFF MAX-DIGITS save new cornerstone save erase spiwe waitspi random
randombit delay ticks now leds ms endcase endof of case s" within pad unused ." mod / /mod move u.r .r d.r rtype u. . d.
ud. (d.) #> #s # sign hold <# hld BUF BUF0 spaces */ */mod fm/mod sm/rem sgn constant variable m* >body create repeat
while else <= >= u<= u>= ( [char] ['] eint? dint eint load spi> >spi spix idle xor! bic! bis! quit evaluate refill accept number
\ char ' postpone literal abort rdrop r@ r> >r hex binary decimal unloop j i +loop loop ?do leave do recurse does> until again
begin then if ahead ; exit :noname : ] [ immediate foldable sliteral s, compile, c, , allot parse parse-name source 2! 2@
cmove> cmove fill sfind align aligned words here tib init forth >in base state /string type count .x .x2 bl cr space c! c@ emit
key key? emit? um/mod * um* d2* d0= m+ s>d dabs d- dnegate d+ depth io@ io! nip over dup swap u< < = invert not or and
xor - + ! 2/ 2* cells abs bounds umax umin max min 2over 2swap +! 2dup ?dup 2drop tuck -rot rot true false drop u> 0> 0<
> 0<> <> cell+ 0= rdepth @ 1- negate 1+ arshift rshift lshift execute  ok.
  ok.
300 FAC .FAC 306,057,512,216,440,636,035,370,461,297,268,629,388,588,804,173,576,999,416,776,741,259,476,533,176,716,
867,465,515,291,422,477,573,349,939,147,888,701,726,368,864,263,907,759,003,154,226,842,927,906,974,559,841,225,
476,930,271,954,604,008,012,215,776,252,176,854,255,965,356,903,506,788,725,264,321,896,264,299,365,204,576,448,
830,388,909,753,943,489,625,436,053,225,980,776,521,270,822,437,639,449,120,128,678,675,368,305,712,293,681,943,
649,956,460,498,166,450,227,716,500,185,176,546,469,340,112,226,034,729,724,066,333,258,583,506,870,150,169,794,
168,850,353,752,137,554,910,289,126,407,157,154,830,282,284,937,952,636,580,145,235,233,156,936,482,233,436,799,
254,594,095,276,820,608,062,232,812,387,383,880,817,049,600,000,000,000,000,000,000,000,000,000,000,000,000,000,
000,000,000,000,000,000,000,000,000,000,000 ok.
