[SOLVED] the best way to use 16MHz crystal (given board [STM32F1]) ?
KHODIDAS11
Re: [SOLVED] the best way to use 16MHz crystal (given board [STM32F1]) ?
Post by KHODIDAS11 » Sat Jan 27, 2018 7:07 am
Hi
Done with 12Mhz also,
found help from https://github.com/rogerclarkmelbourne/ ... _setup.cpp
I observed my PLL multiplier was at 3 which gives clock peripherals as 36Mhz
I have done PLL multiplier as 2, so PLL runs at 24 MHz now. and works all peripherals fine now.
Post by RogerClark » Sat Jan 27, 2018 11:10 am
Pll is set to multiply by 9 normally.
You would need to multiply by 6
I am not sure if the actual values you write to the Pll control register for either Pll multiplier
