STM32-UNO(ARMDuino)
zauberer
STM32-UNO(ARMDuino)
Post by zauberer » Sat Feb 10, 2018 6:46 am
For my students I have designed open source easy to use compatible with Arduino UNO board with STM32F103C8T6 chip – STM32-UNO.
Analog inputs on STM32- UNO are +5V tolerant due to passive voltage divider.
Additional UART port.
External ST Link v.2 programmer/debugger easy connected to right mounted connector. One programmer can be used for many boards.
One user red LED .
One user pushbutton.
Micro-USB port.
VBAT connector to STM32 internal RTC.
BOOT jumpers.
Integrated with DC-DC Step-down power chips 1117XX(+5V and +3V3), it can provide highly efficient and stable power for the shields and other modules, especially suitable for those who want to build a product.
STM32-UNO-Assembly.pdf
(195.6 KiB) Downloaded 32 times
STM32-UNO-Schematic.pdf
(162.84 KiB) Downloaded 34 times
ARMDuino.docx
(157.08 KiB) Downloaded 20 times
zauberer
Re: STM32-UNO(ARMDuino)
Post by zauberer » Sat Feb 10, 2018 6:47 am
Bill of Materials
STM32-UNO(ARMDuino)Bill.pdf
(37.69 KiB) Downloaded 9 times
Post by stevestrong » Sat Feb 10, 2018 7:26 am
Nice, thanks for sharing.
Vassilis
Post by Vassilis » Sat Feb 10, 2018 11:35 am
Very nice, well done !
One small thing to notice: If you want to use any analog pin (A0-A5) as digital output, the maximum current you can get is 3.3v / 12000 ohm = 0.000275 Amp that is not enough to light an LED. Moreover, the Amp loss through the R11, R13,..,R21 to the GND is 3.3V / 18000 = 0.18 mA but is too low to concern you.
Maybe it is a good idea to use an extra pin header that is directly connected to pins PA0-PA7 (or through small value resistors).
Post by Pito » Sat Feb 10, 2018 2:14 pm
Is the PA12 usb resistor wired properly?
Slammer
Post by Slammer » Sat Feb 10, 2018 2:31 pm
It is pulled down with 4K7... I think that must be pulled up with 1K5....
Is this working?
Post by RogerClark » Sat Feb 10, 2018 9:08 pm
Is this working?
Probably works on his machine, in the same way the Blue Pill works for most people, even though it’s wrong
Also..
Btw.
SeeedStudio used to sell a board very similar to this... I have one. It’s a nice board, but I never use it, as it’s unnecessarily big for real world projects
zauberer
Post by zauberer » Sat Feb 10, 2018 10:46 pm
I use resistive devider to protect STM32 analog pins from 5V input sygnal. All Arduino shields are 5V devices.
Students connect LEDs, usually, to PWM channels to study STM32 timers.
In my real work I use STM32+CPLD+Analog.
I am Quartus-Altium-LabView-C teacher.
zauberer
Post by zauberer » Mon Feb 19, 2018 9:20 pm
Post by victor_pv » Mon Feb 19, 2018 11:13 pm
Nice work.
R6 is definitely wrong. Rather than a pull down it should be a pull up, and the correct resistor value is 1k5. Otherwise it may work on some computers and fail on others.
I just replaced the wrong resistors in a couple of bluepills after then would randomly fail half way during sketch uploads.
