ECA Board Issues
Re: ECA Board Issues
Post by zmemw16 » Wed Dec 02, 2015 8:53 pm
i'm going to regret this, but why can't you just waggle the lot?
Post by RogerClark » Wed Dec 02, 2015 9:02 pm
zmemw16 wrote:i'm going to regret this, but why can't you just waggle the lot?
I see what you mean, but...
It seems bad practice, as we have no idea what people have connected to the pins or even if they are shorted to GND etc
And it would be impossible to flash the led without constantly reseting the usb
BrotherV
Post by BrotherV » Thu Dec 03, 2015 9:54 am
[quote="RogerClark"]
Hello Roger, it's connected to PD2. So after I loaded the bootloader should be able to connect the PC directly to the USB on the STM32, Right?
Post by RogerClark » Thu Dec 03, 2015 10:27 am
You need a Bootloader which uses PD2 to reset the USB,
But I just checked and there isnt a version which uses PD2 to cause the USB to re-enumerate
Its fairly easy for me to recompile a new version, but I'm afraid It can't do it today, as its 21:25 local time, and I've just finished work.
i.e I"ve been working for 12 hours as I have a deadline for tomorrow morning
So its too late for me to make you a new bootloader today
Perhaps some other kind person can add you a new build target or perhaps you can make a new target and rebuild it
BrotherV
Post by BrotherV » Thu Dec 03, 2015 3:34 pm
Thanks Roger, hope you are well.
I try my best, I read many topics but how do I change the bootloader for this board? :D
I mean, how do I define the usb reset pin in config.h and how to make a new bin file?!!!!
fredbox
Post by fredbox » Thu Dec 03, 2015 10:56 pm
#elif defined TARGET_ECA
	#define HAS_MAPLE_HARDWARE 1
	#define LED_BANK           GPIOC
	#define LED_PIN            13
	#define LED_ON_STATE	    0
	/* USB Disc Pin Setup.     USB DISC is PD2 */
	#define USB_DISC_BANK      GPIOD
	#define USB_DISC           2
Try this one - USB disc on PD2 and led on PC13.
eca_boot20_fixed.zip
(4.9 KiB) Downloaded 17 times
BrotherV
Post by BrotherV » Fri Dec 04, 2015 6:52 am
	#define LED_PIN            13
	#define USB_DISC           2
Thanks fredbox, ;)
Post by RogerClark » Fri Dec 04, 2015 10:11 am
Thanks Fredbox
I was going to do it at the weekend
One thing to note is that the board will not automatically reset prior to upload
You will need a new board Variant in order to do that.
Probably your best bet is to copy the Maple RET6 folder and change lines 102 and 103 in board/board.h
/* USB configuration.  BOARD_USB_DISC_DEV is the GPIO port containing
 * the USB_DISC pin, and BOARD_USB_DISC_BIT is that pin's bit. */
#define BOARD_USB_DISC_DEV      GPIOC
#define BOARD_USB_DISC_BIT      12
Or just change the Maple RET6 file and use select Maple ret6 from the boards menu
Change it to
#define BOARD_USB_DISC_DEV      GPIOD
#define BOARD_USB_DISC_BIT      2
Then the board should reboot when you upload from the IDE and it should automatically upload via DFU
BrotherV
Post by BrotherV » Fri Dec 04, 2015 12:07 pm
Thanks Roger
Still some questions remaining. I'll ask after the weekend.
I've uploaded bootloader via Demonstrator GUI, but pc13 is not blinking and pc doesn't recognize stm32 board when I plug in the usb cable.
(I've installed maple dfu drivers and changed lines 102 and 103 in board/board.h)
Have a nice weekend
Post by RogerClark » Fri Dec 04, 2015 7:52 pm
Sounds like there is a problem with the firmware @fredbox posted, or possibly the same issue we have with startup on some cheap STM32F103C8 boards
I will try loading the @fredbox firmware onto a "redpill" board that has an led on pc13
Who is online
