Value Line Discovery Board
Any other STM32 based boards
maxxir
Re: Value Line Discovery Board
Post by maxxir » Sat Nov 19, 2016 10:22 am
RogerClark wrote:
You'd need to use that as a standalone IDE as it looks like they must have modified the core files to support the value line board
This is all fairly achedemic now, considering a Value Line board has been added to the stm official code
https://github.com/danieleff/Arduino_Co ... tm_example
by @danieleff
What does it mean academic? I use this fork nearly 2 years - works quite stable and robust. Generated code fairly compact.
IMHO all derived from ST32CUBE is a piece of crap.. Much better to use mature open source libraries (for STM32-Arduino core):
libOpenCM3 or stm32plus from Andy Brown.
ProudPagan
Post by ProudPagan » Wed Feb 15, 2017 4:52 am
Hello Phisatho,
Could you provide the code that you used? I can compile and what seems like upload the
blinky sketch correctly -- see below -- but see no blinking LEDs.
STM32 ST-LINK CLI v2.1.0
STM32 ST-LINK Command Line Interface
ST-LINK SN : ST-Link/V1 on E:
ST-LINK Firmware version : V1J11S0 (Need Update)
Old ST-LINK firmware detected!
Please upgrade it from ST-LINK->'Firmware update' menu.
Connected via SWD.
Connection mode : Normal.
Device ID:0x420
Device flash Size : 128 Kbytes
Device family :STM32F100xx Low/Medium density Value Line
Loading file...
Flash Programming:
  File : C:\Temp\arduino_build_100163\sketch_feb14a.ino.bin
  Address : 0x08000000
Flash memory programming...
±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±± 0%
 0%ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ 44%ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ 89%ÛÛÛÛÛÛ 100%
Flash memory programmed in 1s and 435ms.
Programming Complete.
MCU Reset.
Application started.
PP
Phisatho wrote:At last, I got the LEDs blinking.
I have not tested any other peripherals yet.
If anybody is interested, I can share the files.
nikosx
Post by nikosx » Sun May 07, 2017 5:08 pm
Have tested the Serial2 communication with PC and works OK !! Also analogRead from pin. However DAC -analogWrite- does not seem to work..(program freeze).
nikosx
Post by nikosx » Sun May 07, 2017 5:10 pm
Both board LEDs (green - blue) work OK & User Push switch (also with Interrupt)
Post by dannyf » Sun Jun 04, 2017 10:58 am
Where can I get the support files for STM32VLDISCOVERY board?
i'm porting a generic flavor of arduino to ARM chips and this particular board is my stm32 workbench: viewtopic.php?f=42&t=2131
so far, all GPIO, timing, Interrupt, analogRead/Write, UART, hardware SPI/I2C functionalities have been ported over.
Post by RogerClark » Sun Jun 04, 2017 10:32 pm
Link spam to your site has been replaced with a link to the discussion on this site.
