very small STM32F405 board
Any other STM32 based boards
ChrisMicro
Post by ChrisMicro » Sat Jul 22, 2017 3:07 pm
I found this STM32F407 flight controller board which is quite nice. I think it could be easily used for other purposes than flight control.
Is there any direct support for this MCU?
martinayotte
Re: very small STM32F405 board
Post by martinayotte » Sat Jul 22, 2017 3:52 pm
STM32F405 or F407 are already supported since more than 2 years.
Maybe some feature missing, but just tell us which ones ... ;)
Ollie
Post by Ollie » Sat Jul 22, 2017 4:15 pm
Depending on your application, you can reduce your effort and leverage the work done by others by selecting a proper IDE and library. There are quite a many alternatives.
1. If you are doing any flying things, the BetaFlight can be modified for your needs. For most cases, only minor changes are required. As the BetaFlight is based on the ST HAL library, there are a lot of related libraries and documentations available.
2. ST has been working with STM32duino and made the HAL libraries available for many STM32 Nucleo and Disco boards. As such, they can be used with Arduino IDE.
3. STM32duino has its own F4 support. The main target has been F407.
Related to this F405 board, I can observe that it is quite expensive compared to the classic style of boards. On the higher side, it has a limited performance compared to F745 board used in AnyFC-F7. With $30 you can get more connectivity, higher performance, and built-in IMU and still use the same BetaFlight library as used with F405. Many of these advantages are the fruits from the OpenPilot project done during the past years.
Post by RogerClark » Sat Jul 22, 2017 9:48 pm
Looking at the photo in the listing, although it has a lot of pins, many of them seem to be labelled as power and ground .
It is also quite expensive.
So IMHO only if use if you need a small powerful board but don't need many GPIOs
ChrisMicro
Post by ChrisMicro » Sun Jul 23, 2017 5:54 am
I think the main feature of this board is that it is very small 30x30mm and it hast 16MB Flash and a IMU.
The connectors are made to connect servos so it could be used e.g. for a little robot.
Post by RogerClark » Sun Jul 23, 2017 7:07 am
I agree. Its designed to me a flight controller; and consequentially its less useful as a general purpose board
Post by ag123 » Thu Jul 27, 2017 2:45 pm
there is actually an 'old' thread here discussing 'tiny' stm32f4 boards
http://www.stm32duino.com/viewtopic.php?f=39&t=1977
one of those tiny F407VE boards i got are these
http://www.stm32duino.com/viewtopic.php ... =10#p26277
http://www.stm32duino.com/viewtopic.php ... =40#p27327
at about 2x the breadth of BP/MM 4cmx5cm it qualifies as a 'tiny' board with all the pins broken out and has an on board uSD card slot + on board crystals
then there are some other worthy competitors that are discussed in the thread
among them this board from olimex is pretty compact and decently priced
https://www.olimex.com/Products/ARM/ST/STM32-H405/
and you may also want to take a look at those micropython f405 boards which are true challengers in the 'tiny' arena who makes tiny f405 boards with as many pins broken out as is possible. micropython also throws in a 3 axis accelerometer MMA7660 on board and an ultra compact uSD card slot on a really tiny form factor
https://store.micropython.org/store/
Post by victor_pv » Thu Jul 27, 2017 3:58 pm
Just for reference, I recently bought one of these:
https://www.aliexpress.com/item/Mini-ve ... fbb0123c5e
It's really small (50x40mm) but includes an i2c eeprom, and sdcard slot, and all MCU pins broken out.
I have still not used it, but plan to use it for my marlin tests.
Ollie
Post by Ollie » Thu Jul 27, 2017 6:51 pm
This F407VE has become my new favorite board. I am calling it "blue pad" and it is kind of super "blue pill".
Post by Pito » Thu Jul 27, 2017 8:53 pm
What is the tiny voltage reg there on the board?
