VL53L1X Example code?
ZanderSTM
Post by ZanderSTM »
Hi guys,
Anyone have some example code using the STM32duino_VL53L1X library? I'm new to programming and am having difficulty making sense of the .CPP and .H files.
Thanks!
Answers: 91
Re: VL53L1X Example code?
you can have a look at this library which use it:
https://github.com/stm32duino/X-NUCLEO-53L1A1
ZanderSTM
Post by ZanderSTM »
Thanks, I managed to figure it out. For future reference the code below is a simple setup with one VL53L1X (based off the example given in the X-NUCLEO-53L1A1 libaray):
#include <ComponentObject.h>
#include <RangeSensor.h>
#include <vl53l1x_class.h>
#include <vl53l1_error_codes.h>
VL53L1X *sensor1;
#define DEV_I2C Wire
  	Serial.println("Starting...");
  	Wire.begin();
 	sensor1 = new VL53L1X(&DEV_I2C, PA12, PA15);
  	sensor1 ->VL53L1_Off();
  	sensor1 -> InitSensor(0x10);
 	int status;
  	uint8_t ready = 0;
  	uint16_t distance;
 	sensor1 -> VL53L1X_StartRanging();
  	do {
   		sensor1 -> VL53L1X_CheckForDataReady(&ready);
  	} while (!ready);
  	status = sensor1 -> VL53L1X_GetDistance(&distance);
  	if (status == VL53L1_ERROR_NONE) {
    	Serial.print(0);  // To freeze the lower limit
    	Serial.print(" ");
    	Serial.print(4000);  // To freeze the upper limit
   	Serial.print(" ");
    	char report[64];
    	snprintf(report, sizeof(report), "Distace top [mm]: %d ", distance);
    	Serial.println(report);
  	status = sensor1 -> VL53L1X_ClearInterrupt();
Cheers, ZanderSTM
