Maple Mini DFU and Serial
Re: Maple Mini DFU and Serial
Post by Pito » Wed Apr 20, 2016 8:24 pm
http://www.nirsoft.net/utils/usb_devices_view.html
http://www.softpedia.com/get/System/Sys ... view.shtml
For 64bit take the 64bit version.
If you want to uninstall the usb devices you have to go Help->Run as admin.
USB Maple DFU and Serial.txt
(2.2 KiB) Downloaded 161 times
Post by RogerClark » Wed Apr 20, 2016 10:33 pm
Try on a different computer and also with a different cable
And of course your Maple Mini board could be faulty e.g. some sort of USB reset hardware issue
Post by mrburnette » Thu Apr 21, 2016 1:04 am
RogerClark wrote:Try on a different computer and also with a different cable
... which is why I advocate buying 2 of inexpensive hardware. I just went thru the faux NodeMCU mess with only 1 piece of hardware. Drove me crazy. The second (and third) arrived yesterday and the new one works perfectly with the recommended IDE settings and the exact same sketch. Results: bad hardware.
Post by Pito » Thu Apr 21, 2016 8:39 am
I will try with the second one :)
On the other hand the cable and DFU and basic MM hardware seems to be working (my test sketch via Serial1 and uart1):
Claiming USB DFU Interface...
Setting Alternate Setting ...
dfuIDLE, continuing
Transfer Size = 0x0400
bytes_per_hash=2139
Done!
Hello World!
x= 3444444444445555555555666666.6666678
y= -56666666666677777777777788.888888888
z=x+y= 3387777777778877777777888877.7777789
3.387777777778878e+27
elapsed: 42 us
z=x-y= 3501111111112233333333444455.5555567
3.501111111112233e+27
elapsed: 45 us
z=x*y= -1.9518518518528641975309276666666673E+53
-1.951851851852864e+53
elapsed: 93 us
z=x/y= -60.784313725497885428683223790246607
-6.078431372549789e+01
elapsed: 314 us
z=cos(0.7)= 0.76484218728448842625585999019186493
7.648421872844884e-01
elapsed: 6665 us
Post by Pito » Thu Apr 21, 2016 8:56 pm
Tried my second MM (Baite). 2 different cables, 4 diff ports. The same behavior as above.
Luckily at least the DFU mode works ;)
Post by RogerClark » Thu Apr 21, 2016 8:59 pm
You could try replacing the old bootloader which comes preinstalled with the new one.
Its not going to be any worse than what you have now.
Post by Pito » Fri Apr 22, 2016 7:56 am
Flashed maple_mini_boot20.bin via stlink.
Board set MM with bootloader 2.0.
Sketch under Arduino 1.6.5.:
Serial.println("Hello");
Sketch uses 12,388 bytes (10%) of program storage space. Maximum is 122,880 bytes.
Global variables use 2,560 bytes of dynamic memory.
C:\Users\pito\MyCode\Arduino\hardware\Arduino_STM32/tools/win/maple_upload.bat COM4 2 1EAF:0003 C:\Users\pito\AppData\Local\Temp\build3574855099985480588.tmp/STM32_Test_Maple.cpp.bin
maple_loader v0.1
Found it!
Found Runtime: [0x1eaf:0x0003] devnum=1, cfg=0, intf=0, alt=2, name="STM32duino bootloader v1.0  Upload to Flash 0x8002000"
Setting Configuration 1...
dfuIDLE, continuing
bytes_per_hash=247
Done!
After reset the "Maple" in "Other devices" with ! in yellow triangle
The drivers for this device are not installed. (Code 28)
None Maple in Ports.
Does it compile the usb serial into the sketch?
Vassilis
Post by Vassilis » Fri Apr 22, 2016 8:18 am
Click on the yellow icon (in other devices) and install the maple serial driver.
Arduino_STM32\drivers\win\win_xp_legacy\maple-serial\usb_device.inf
Post by Pito » Fri Apr 22, 2016 8:40 am
Error installing driver - the name is already in use.
I see now a "COM9" in "Other devices" with ! in yellow triangle however :)
Using win7 64bit btw.
Vassilis
Post by Vassilis » Fri Apr 22, 2016 8:49 am
Install Zadig http://zadig.akeo.ie/downloads/zadig_2.2.exe
Zadig is a Windows application that installs generic USB drivers, such as WinUSB, libusb-win32/libusb0.sys or libusbK, to help you access USB devices.
