STM32F103C8T6 need help with drivers
petronel
Re: STM32F103C8T6 need help with drivers
Post by petronel » Wed Nov 09, 2016 8:26 pm
#define pinLED PC13
   Serial.println("start");
  digitalWrite(pinLED, HIGH);
  delay(500);
  digitalWrite(pinLED, LOW);
  Serial.println("Hello World2");
    delay(100);
This is the sketch I use.
Even that i use PC13, led doesn't blink..
When the sketch start, I can't see the msg from setup(). I have to move BOOT0 to LOW and reset.
Not sure why Led is not blinking.
I have a 1k5 resistor soldered between PA12 and 3.3 like wiki suggested, that might be a problem ?
Post by stevestrong » Wed Nov 09, 2016 8:35 pm
Of course it doesn't blink, because you forgot to set the pin mode.
Insert to setup() the following line:
pinMode(pinLED, OUTPUT);
petronel
Post by petronel » Wed Nov 09, 2016 8:43 pm
:oops: forgot about that. THANKS !!!
Now i noticed that the F macro doesn't work
Serial.println(F("test"));
If i remove the F() , then it works.
I'm trying to use https://github.com/miguelbalboa/rfid
Added
#define F(x) x
Post by RogerClark » Wed Nov 09, 2016 9:01 pm
Umm
I'm not sure why the F macro doesnt work any more.
But I agree its now crashing if I try to use it
Actually, the F macro is not needed for ARM dev at all, and should be removed wherever possible
Looks like F is defined in WString.h
#define F(string_literal) (reinterpret_cast<const __FlashStringHelper *>(PSTR(string_literal)))
Looks like its in the Arduino SAM Wstring as well
https://github.com/arduino/Arduino/blob ... /WString.h
petronel
Post by petronel » Wed Nov 09, 2016 9:19 pm
Removing all the F() from that RFID library might be a pain.
#define F(x) x
seems to do the job..
but the code seems to stop at
mfrc522.PCD_DumpVersionToSerial();
maybe something to do with the SPI .. ?
SPI.beginTransaction(SPISettings(SPI_CLOCK_DIV4, MSBFIRST, SPI_MODE0));
Anyone had success using MFRC522 with the STM32?
Post by stevestrong » Wed Nov 09, 2016 9:39 pm
And where do you set the chip select CS pin for the SPI?
SPI.beginTransaction(CHIP_SEL, SPISettings(SPI_CLOCK_DIV4, MSBFIRST, SPI_MODE0));
petronel
Post by petronel » Wed Nov 09, 2016 10:09 pm
In my sketch i have
#define RST_PIN         PA0          // Configurable, see typical pin layout above
#define SS_PIN         PA1          // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN);  // Create MFRC522 instance
Constructor is
MFRC522::MFRC522(	byte chipSelectPin,		///< Arduino pin connected to MFRC522's SPI slave select input (Pin 24, NSS, active low)
					byte resetPowerDownPin	///< Arduino pin connected to MFRC522's reset and power down input (Pin 6, NRSTPD, active low)
	_chipSelectPin = chipSelectPin;
	_resetPowerDownPin = resetPowerDownPin;
} // End constructor
Init is:
void MFRC522::PCD_Init() {
	// Set the chipSelectPin as digital output, do not select the slave yet
	pinMode(_chipSelectPin, OUTPUT);
	digitalWrite(_chipSelectPin, HIGH);
	// Set the resetPowerDownPin as digital output, do not reset or power down.
	pinMode(_resetPowerDownPin, OUTPUT);
	if (digitalRead(_resetPowerDownPin) == LOW) {	//The MFRC522 chip is in power down mode.
		digitalWrite(_resetPowerDownPin, HIGH);		// Exit power down mode. This triggers a hard reset.
		// Section 8.8.2 in the datasheet says the oscillator start-up time is the start up time of the crystal + 37,74μs. Let us be generous: 50ms.
		delay(50);
	else { // Perform a soft reset
		PCD_Reset();
	// When communicating with a PICC we need a timeout if something goes wrong.
	// f_timer = 13.56 MHz / (2*TPreScaler+1) where TPreScaler = [TPrescaler_Hi:TPrescaler_Lo].
	// TPrescaler_Hi are the four low bits in TModeReg. TPrescaler_Lo is TPrescalerReg.
	PCD_WriteRegister(TModeReg, 0x80);			// TAuto=1; timer starts automatically at the end of the transmission in all communication modes at all speeds
	PCD_WriteRegister(TPrescalerReg, 0xA9);		// TPreScaler = TModeReg[3..0]:TPrescalerReg, ie 0x0A9 = 169 => f_timer=40kHz, ie a timer period of 25μs.
	PCD_WriteRegister(TReloadRegH, 0x03);		// Reload timer with 0x3E8 = 1000, ie 25ms before timeout.
	PCD_WriteRegister(TReloadRegL, 0xE8);
	PCD_WriteRegister(TxASKReg, 0x40);		// Default 0x00. Force a 100 % ASK modulation independent of the ModGsPReg register setting
	PCD_WriteRegister(ModeReg, 0x3D);		// Default 0x3F. Set the preset value for the CRC coprocessor for the CalcCRC command to 0x6363 (ISO 14443-3 part 6.2.4)
	PCD_AntennaOn();						// Enable the antenna driver pins TX1 and TX2 (they were disabled by the reset)
} // End PCD_Init()
All code is at https://github.com/miguelbalboa/rfid/
Not sure how to tell to use SPI1 or SPI2. My RFID is connected to PA5, PA6, PA7 with CS at PA1
petronel
Post by petronel » Wed Nov 09, 2016 10:57 pm
I just had a "Doh!!" moment. :oops:
Found my problem with the bootloader:
I was using Flash Loader Demonstrator, and instead of "Download to device" I was using "Upload from device" , probably didn't read to / from.
So I've overwrite the generic_boot_pc13.bin with the one that was on device :roll:
Now i see the DFU I upload my sketch and after it reset I get a Maple Serial.
Post by RogerClark » Wed Nov 09, 2016 11:32 pm
:lol:
I agree. The terminology used is confusing.
petronel
Post by petronel » Wed Nov 09, 2016 11:52 pm
Probably I was expecting Download from and Upload to .. it makes more sense to me.
I have 2 other questions now:
1. After a sketch is uploaded and the STM32 is resetting, the Serial connection drop for a second, and I have to close/open the Serial Monitor. Is that normal ?
2. Uploading a sketch that compile ok but crash when running (like my test with RFID) make the DFU / com disappear and getting again "Unknown device". I can still reset the STM32 and upload an working sketch.
