[COMPLETED] Combining Blink & Count to the bootloader
Post by RogerClark » Mon Jun 19, 2017 1:52 am
[Update by admin]
This proposal has now been made to the bootloader, except the sketch does not blink as this would require a different sketch binary for every bootloader / board. So instead it prints a message to Serial
Guys
A problem that we get over and over again, is people expecting to get the Serial device when they first load the bootloader
I don't propose to add even a fake serial device to the bootloader, as composite devices are problematic on Windows.
But, combining a Blink & Count sketch to the bootloader binary, so that when new users load the bootloader, the board appears and has a com port that the IDE can see, seems like a possible solution to this.
I did consider adding some other form of demo sketch to the bootloader, but it would need to be purely text based, or just involve blinking or fading the LED.
Does anyone have any thoughts on this one.
Also... I don't know an easy way of merging binaries or hex files. I have a tool called mergehex (from Nordic Semi) but it doesn't seem to work for this (possibly it only works on specific address ranges)
zoomx
Re: Combining Blink & Count to the bootloader
Post by zoomx » Mon Jun 19, 2017 6:06 am
An hex editor maybe?
Post by RogerClark » Mon Jun 19, 2017 7:18 am
I can do it using the Jlink JFlash tool as it has a merge feature but its a pain to do it manually for all the files.
I will try again to see if I can make Nordic's MergeHex utility work
danieleff
Post by danieleff » Mon Jun 19, 2017 7:54 am
But isn't it just appending one to the other? I know you use Windows, but:
cat bootloader.bin > bootloader_plus_blink.bin
truncate -s8192 bootloader_plus_blink.bin
cat blink.bin >> bootloader_plus_blink.bin
Post by stevestrong » Mon Jun 19, 2017 9:15 am
I am using HxD: https://mh-nexus.de/en/hxd/
It supports, among many interesting features, splitting or concatenating of files, too.
Post by RogerClark » Mon Jun 19, 2017 10:35 am
Does that work.
The bootloader bin size is not 8192 it is smaller, and is likely to change if we modify it.
Also the sketch bin file does not have 0x00 in the first 0x2000 bytes.
I think its going to be easier for me to just write a windows command line tool to do this using fread and fwrite
All I need to know is the size of the Blink bin
So in pseudo code
Open Blink
get size of blink binary
Malloc size of blink binary + 0x2000
Read blink into 0x2000
read bootloader in 0x0000
Write whole of malloced area to disk
Post by RogerClark » Mon Jun 19, 2017 10:36 am
I was hoping to find something which I could run from a windows bat file
danieleff
Post by danieleff » Mon Jun 19, 2017 10:39 am
Does that work.
`truncate -s8192 bootloader_plus_blink.bin` extends the file to be 8192 bytes. I guess there is similar in windows, maybe in powershell, or some util file.
Post by RogerClark » Mon Jun 19, 2017 10:41 am
Does that work.
Ah OK
I'll see if windows powershell has this
Edit.
No. It does not have that command.
I'm going to write a windows command line tool.
It should be easy, I have CodeBlocks installed. I also have MS Visual Studio but it tends to include loads of extra libs that are a problem e.g. MS VC libs just for simple exe's
Post by stevestrong » Mon Jun 19, 2017 11:42 am
For your orientation, here is a command line hex editor, with source code:
https://sourceforge.net/projects/hexciting/
