blue pill upload only after reset
charsi
Post by charsi » Sun Jul 23, 2017 8:44 am
Hi
I got my first stm32 board - the blue pill yesterday and managed to get it up and running (after a few hiccups). However currently I am having to hit reset every time I want to upload a sketch using arduino ide. I have to time it perfectly so that when arduino tries to upload the chip still has its light blinking rapidly but this is a bit difficult sometimes. Any way to fix this?
Re: blue pill upload only after reset
Post by RogerClark » Sun Jul 23, 2017 10:14 am
You need to select the COM port in the IDE otherwise it wont reset
Also you need to select the correct board type in the IDE
charsi
Post by charsi » Sun Jul 23, 2017 2:55 pm
I've got '/dev/ttyACM0 (Maple Mini)' selected as the COM port and STM32F103C as the board type. So not sure what I am doing wrong.
I get the following error message if I try to upload without hitting reset button--
dfu-util 0.8
dfu-util: Invalid DFU suffix signature
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
dfu-util: A valid DFU suffix will be required in a future dfu-util release!!!
Copyright 2010-2014 Tormod Volden and Stefan Schmidt
Please report bugs to dfu-util@lists.gnumonks.org
dfu-util: No DFU capable USB device available
Waiting for /dev/ttyACM0 serial...Done
lsusb lists my device as follows so it is definitely being recognised.
Bus 001 Device 006: ID 1eaf:0004
However dfu-util doesn't list anything unless I run dfu-util -l right after pressing reset. In that case I get this --
Found DFU: [1eaf:0003] ver=0201, devnum=5, cfg=1, intf=0, alt=2, name="STM32duino bootloader v1.0  Upload to Flash 0x8002000", serial="LLM 003"
Found DFU: [1eaf:0003] ver=0201, devnum=5, cfg=1, intf=0, alt=1, name="STM32duino bootloader v1.0  Upload to Flash 0x8005000", serial="LLM 003"
Found DFU: [1eaf:0003] ver=0201, devnum=5, cfg=1, intf=0, alt=0, name="STM32duino bootloader v1.0  ERROR. Upload to RAM not supported.", serial="LLM 003"
