Page 1 of 2
[Solved] error: 'isnan' was not declared in this scope isnan(n);
Posted: Tue Jun 16, 2020 6:09 pm
by geostroud
I am working on a project for a generic STM32F103C series board which uses a nRF24L01 transceiver module. It compiled just fine but I was having problem with transceiver modules. I had to take a two week break from the project. A couple of days ago, I decided to start work on the project again but when I went to rebuild the project using the Arduin 1.8.12 (Windows 8.1) IDE I get the following compiler error:
D:\Documents\Arduino\sketch_jun12a\sketch_jun12a.ino: In function 'void loop()':
sketch_jun12a:9:10: error: 'isnan' was not declared in this scope
isnan(n);
When I restarted work on the project, I installed all of the board and library updates were available on 2020/06/12. In an effort to resolve this problem I installed all library and board updates again today 2020/06/16. On both the dates there was a board update for the STM32F1xx/GD32F1xx boards that I installed. In an effort to simplify trouble shooting the problem I created the following simple sketch:
double n = 0;
isnan(n);
I can successfully compile this simple script for the Arduino UNO, ESP32 and ESP8266 boards with no compile errors. However, as soon as I select board type "Generic STM32F103C Series" I get the above error. isnan() is a common function defined in math.h which is normally included from arduino.h. Can anyone help.
Re: error: 'isnan' was not declared in this scope isnan(n);
Posted: Tue Jun 16, 2020 6:20 pm
by geostroud
I went back through the board updates for the "STM32F1xx/GD32F1XX boards". This issue starts with version 2020.2.26. If I revert back to the 2020.5.18 version of the board the sketch compiles without error.
Posted: Wed Jun 17, 2020 8:16 am
by stevestrong
Can you please indicate the correct date from which the issue starts and which version is working?
Because I just tried your example with the latest (Roger's libmaple) core version and it compiles error free.
Posted: Wed Jun 17, 2020 2:08 pm
by geostroud
If you check the update I posted, you will find the information you are requesting.
Posted: Wed Jun 17, 2020 2:12 pm
by geostroud
Sorry, I see that I made a typo. 2020.5.18 works. Versions 2020.5.26 thru 2020.6.16 fail.
Posted: Fri Jun 19, 2020 2:17 pm
by stevestrong
This error is only shown with the original 4.8.3 GCC compiler version. Because I use 7.2.1, this was not visible.
The solution is to insert:
before setup().
I just committed a fix in the repo.
Please check out the latest version and let me know if it works.
Posted: Fri Jun 19, 2020 4:34 pm
by geostroud
The latest version that shows up as of today 06/19/2020 is version 2020.6.17 and it down resolve the problem. While I created a simple test sketch to illustrate the issue, the actual sketch that I am working on uses the BME280 library and the library uses the isnan() function. Therefore, while inserting the suggested include and using statement while circumventing the issue with the test sketch, it does not resolve the issue with my real sketch as I would have to locate and modify the routines using this function. They are not mine to modify.
Also, I as a user of the arduino IDE do not control what level of the GCC compiler is used. I am not even sure when and were the proper CC compiler is installed and configured.
Posted: Sat Jun 20, 2020 9:29 am
by stevestrong
Which BME280 library? Can you post a link to that?
And an example sketch using that library would be also helpful.
Posted: Sun Jun 21, 2020 3:07 am
by geostroud
Posted: Sun Jun 21, 2020 3:16 am
by geostroud
Sketch (STM_WS.ino):
STM_WS.ino
Code for Weather Station that reports temperature, humidity,
barometric pressure and rainfall. Values are reported when
requested by the base station. The rain fall is reset after
each report which makes it the responcibility of the base station
code to track accumulation over time.
Platform: STM32F103C8
Author: George Stroud
Created: Feb 27, 2020.
Last Updated: Apr 08, 2020 (V0.3).
Connecting the nRF24L01+
Transceiver -> STM32F102C
GND -> GND
VCC -> 3.3V
CE -> PB0
CSN -> PA4
SCK -> PA5
MOSI -> PA7
MISO -> PB6
Connecting the BME280 Sensor:
Sensor -> STM32F103C
Vin (Voltage In) -> 3.3V
Gnd (Ground) -> Gnd
SDA (Serial Data) -> PB7 STM32F103C
SCK (Serial Clock) -> PB6 STM32F103C
Connecting the Rain Gauage
VCC -> 3.3v
GND -> GND
Signal -> PC13
#include <BME280I2C.h>
#include <SPI.h>
#include <RF24-STM.h>
#include <WS_Lib.h> // In D:\Documents\Arduino\libraries\GeoS_Library
#include <math.h>
using namespace std;
#define SERIAL_BAUD 115200
#define LedPin PC13
#define RGPin PC15
BME280I2C bme;
RF24 radio(PB0,PA4);
data wsData;
_cmd wsCmd;
volatile unsigned long rainIntCnt = 0;
// SETUP SETUP SETUP SETUP SETUP SETUP SETUP SETUP SETUP
pinMode(LedPin, OUTPUT);
Serial.begin(SERIAL_BAUD);
while(!Serial) {} // Wait
Wire.begin();
while(!bme.begin()) {
Serial.println("Could not find BME280 sensor!");
} // end "while..."
Serial.print("chipModel:");
Serial.println(bme.chipModel());
switch(bme.chipModel()) {
case BME280::ChipModel_BME280:
Serial.println("Found BME280 sensor! Success.");
break;
case BME280::ChipModel_BMP280:
Serial.println("Found BMP280 sensor! No Humidity available.");
break;
default:
Serial.println("Found UNKNOWN sensor! Error!");
} // end "switch..."
// Initiate the radio object
radio.begin();
// Set the transmit power to the mid power level
radio.setPALevel(wsPwrLvl);
// Set tje s[eed pf tje transmission to the 250KBS
radio.setDataRate(wsDataRate);
// Use a channel unlikely to be used by Wifi, or other 2.4GHz devices
radio.setChannel(wsChan);
// Open a writing and reading pipe on each radio, with opposite addresses
radio.openReadingPipe(1, wsRdPipe);
radio.openWritingPipe(ws1TxPipe);
// Give the receiver a chance
radio.setRetries(10, 10);
// Auto ackknowledgment of a transmission
radio.setAutoAck(true);
// Listen for Base station request for data
radio.startListening();
// Debugging information
radio.printDetails();
attachInterrupt(digitalPinToInterrupt(RGPin), RainGaugeISR, RISING);
rainIntCnt = 0; // Clear rain gauge interrupt count;
digitalWrite(LedPin,LOW);
Serial.println("STM:WS - Exiting setup");
} // end "setup"
// LOOP LOOP LOOP LOOP LOOP LOOP LOOP LOOP LOOP LOOP LOOP
// Check if command received
if (radio.available())
// Get the command/request
delay(50);
if (radio.read(&wsCmd, sizeof(wsCmd))) {
Serial.println("Read command successful");
printCmd('R', &wsCmd);
if (wsCmd.cmdID == RETRIEVE) {
getData(&wsData);
if (xmitData(&wsData)) // Xmit data to base station
rainIntCnt -= wsData.intCnt; // Adjust rain guage interrupt
printData(&wsData);
} // end "if (wsCmd.cmdID..."
} else { // radop/read(...) failed
Serial.println("Read command failed");
} // end "if (radio.read(...)"
} // end "if (radio.available())"
} // end "loop"
void getData(data *wsData)
Serial.println("getData called");
BME280::TempUnit tempUnit(BME280::TempUnit_Fahrenheit);
BME280::PresUnit presUnit(BME280::PresUnit_inHg);
bme.read(wsData->pres, wsData->temp, wsData->hum, tempUnit, presUnit);
wsData->intCnt = rainIntCnt;
wsData->rain = (rainFactor * wsData->intCnt);
} // end "getData..."
bool xmitData(data *wsData)
Serial.println("xmitData called");
bool state = digitalRead(LedPin);
digitalWrite(LedPin, !state);
// Transmit data to base station
radio.stopListening(); // Ensure we have stopped listening
if (radio.write(wsData, sizeof(*wsData))) {
Serial.println("TX: ACK");
return true;
} else {
Serial.println("TX: No ACK");
return false;
} // end "if (!radio.write..."
} // end "xmitData..."
void RainGaugeISR()
rainIntCnt++;
My library routine (WS_Lib.h):
// Last Updated: 2020/04/29 (V0.3)
// WS_Lib.h
#ifndef MY_WS_H
#define MY_WS_H
#define wsRdPipe 0xB3B4B5B601 // Pipe on which ws base station transmits
#define ws1TxPipe 0xB3B4B5B602 // Pipe on which ws1 THBp transmits
#define ws2TxPipe 0xB3B4B5B603 // Pipe on which ws2 Anamometer transmits
#define wsChan 125 // Transmission channel
#define wsTimeOut 5000 // Base Station will wait up to 5 seconds
// for weather statiion reply
#define wsDataRate RF24_250KBPS // RF24_250KBPS, RF24_1MBPS, RF24_2MBPS
#define wsPwrLvl RF24_PA_MAX // RF24_LOW, RF24_MAX
#include <time.h>
struct data {
float temp; // Temperature
float hum; // Humidity
float pres; // Barometric Pressure
float rain; // Rain Fall since last read
unsigned long intCnt; // Count of interrupts from rain gauge (fcr calabration)
}; // end "data"
#define RETRIEVE 'R' // Retrieve and return Weather Station Data.
struct _cmd {
char cmdID; // Command for Weather Station. Currently only 'F' for fetch data supported.
char subCmd; // Optional sub-command, Currently no sub-commands are supported.
}; // end "_cmd"
// char MyTm[18] = 0;
#define rainFactor .0158 // Rain Fall per sensor bucket tip
#ifdef _RPI_
void MyTime(char *logtm)
time_t mytime;
struct tm *mytm;
mytime = time(NULL);
mytm = localtime(&mytime);
sprintf(logtm,"%4d-%02d-%02d %02d:%02d",
1900 + mytm->tm_year, mytm->tm_mon,
mytm->tm_mday, mytm->tm_hour, mytm->tm_min);
} // end "MyTime()"
void printData(char *logtm, data *wsData)
printf("%s Temp: %.2fF\tHumidity: %.2f% RH\tPressure: %.2f inHg"
"\tRain: %.2f in (%u)\n", logtm, wsData->temp, wsData->hum,
wsData->pres, wsData->rain, wsData->intCnt);
} //end "printData..."
void printCmd(char *logtm, _cmd *wsCmd)
printf("%s CMD Received: CMD=%c, SubCMD=%c\n", logtm, wsCmd->cmdID, wsCmd->subCmd);
} // end "printCmd..."
void logData(char *logfile, char *logtm, data& wsData)
FILE *filePtr;
filePtr = fopen(logfile,"a");
if (filePtr == NULL) {
fprintf(stderr, "Failed to open log file.\n");
} else {
fprintf(filePtr, "%s,%.2f,%.2f,%.2f,%.2f,%u\n",
logtm, wsData.temp, wsData.hum, wsData.pres,
wsData.rain, wsData.intCnt);
fclose(filePtr);
} // end "If (filePtr..."
} // end "logData(..."
#else
void printData(data *wsData)
Serial.print("Temp: ");
Serial.print(wsData->temp);
Serial.print("F");
Serial.print("\tHumidity: ");
Serial.print(wsData->hum);
Serial.print("% RH");
Serial.print("\tPressure: ");
Serial.print(wsData->pres);
Serial.print(" inHg");
Serial.print("\tRain: ");
Serial.print(wsData->rain);
Serial.print(" in (");
Serial.print(wsData->intCnt);
Serial.println(")");
void printCmd(char lbl, _cmd *wsCmd)
if (lbl=='S')
Serial.print("CMD Sent: CMD=");
else if (lbl=='R')
Serial.print("CMD Received: CMD=");
else
Serial.print("CMD Struct: CMD=");
Serial.print(wsCmd->cmdID);
Serial.print(", SubCMD=");
Serial.println(wsCmd->subCmd);
#endif // MY_WS_H
