Change clock, from external 72MHz to internal 48MHz
billys7
Post by billys7 »
Hello,
I want to use an STM32F103 without external oscillators. My experiments are on a Bluepill and I am trying to change the clock from external clock 72MHz to internal clock 48MHz. I know which registers i have to change, but i don't think that it is so easy. I can't make it to work.
What is the procedure?
Answers: 91
Re: Change clock, from external 72MHz to internal 48MHz
simply redefine at sketch level the void SystemClock_Config(void) as this is a WEAK (for ref: https://github.com/stm32duino/Arduino_C ... t.cpp#L105)
Use extern "C" else this wil not work:
extern "C" void SystemClock_Config(void) {
  /* Your custom clock config */
billys7
Post by billys7 »
Thank you!
