[SOLVED] Uploading via STLink-v2 problem
peeknot
Post by peeknot » Thu Jan 04, 2018 1:46 pm
Before I know that I can use stlink as a uploader and can open the port by connecting usb cable to usb port. I uploaded bootloader to the bluepill , so my question is
1.) Is it okay to upload via STLink with the board having the bootloader?
2.) If 1 is yes , does the bootloader disappear after uploading via STLink?
3.) After resetting everything in drivers, still the stlink cant communicate with the board. Any method on how to fix this?
Re: Uploading via STLink-v2 problem
Post by zmemw16 » Thu Jan 04, 2018 1:51 pm
yes,yes, need more info
i.e. which os, which distro if applicable, which core, which arduino version and anything else you might be useful
srp
peeknot
Post by peeknot » Thu Jan 04, 2018 1:57 pm
Im using windows 8 , arduino version 1.6.10 , stm32f103c8t6 sorry for not giving the info
Post by zmemw16 » Thu Jan 04, 2018 2:03 pm
as it's winxx it's almost certain it's a driver issue
i'm on linux so not that helpful.
which core ? arduino_stm32(roger), ST(ftpSTM??) official, one of the STM32GENERIC's ?
srp
peeknot
Post by peeknot » Thu Jan 04, 2018 2:18 pm
Im not quite sure about the core , but Im using the arduino_st(roger) , the first time I use the stlink is successful but after uploading bootloader on it and back to stlink for uploading method the stlink dont communicate with the board sorry for the inconvenience
Post by zmemw16 » Thu Jan 04, 2018 2:45 pm
why are you trying to st-link upload after installing the bootloader ?
select the bootloader as the upload method and try again .
peeknot
Post by peeknot » Thu Jan 04, 2018 2:55 pm
thanks for the guide sir stephen , gonna move this thread to uploading i was on the wrong one :lol:
Post by zmemw16 » Thu Jan 04, 2018 3:01 pm
wow i totally missed the sword touch on each shoulder :lol:
Post by stevestrong » Thu Jan 04, 2018 3:22 pm
You need the bootloader only if you want to upload over USB DFU.
In this case the STLink interface is disabled, that is why you cannot access the chip with the STLink.
STLink DOES NOT WORK AS SERIAL PORT!!!
You have to connect a USB cable to the USB socket of the board to have USB serial interface.
peeknot
Post by peeknot » Thu Jan 04, 2018 3:35 pm
How can I enable the STLink interface?
Yes I know that sir , sorry for the inconvenience. The problem was on the STLink interface that I think it was disable
