[SOLVED] Uploading via STLink-v2 problem
Re: Uploading via STLink-v2 problem
Post by stevestrong » Thu Jan 04, 2018 10:06 pm
You have to upload over USB DFU a simple (blinky) sketch built with compiler option
-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1
inserted at the end of line 374.
Or you can try to upload via STLink but then press the reset button on the board right after Arduino IDE has completed to build the project and starts to upload. Precise timing is necessary here.
peeknot
Post by peeknot » Fri Jan 05, 2018 4:58 am
Yay solved , thanks steve
Best Regards
Kevin
