TimerInterrupt_Generic Library to merge all TimerInterrupt Libraries
khoih-prog
Post by khoih-prog »
This library enables you to use Interrupt from Hardware Timers on supported Arduino boards such as AVR, ESP8266, ESP32, SAMD, SAM DUE, nRF52, Teensy, etc.
As Hardware Timers are rare, and very precious assets of any board, this library now enables you to use up to 16 different ISR-based timers, while actually consuming only 1 Hardware Timer. Timers' interval is very long (ulong millisecs). The most important feature is they're ISR-based timers. Therefore, their executions are not blocked by bad-behaving functions or tasks. This important feature is absolutely necessary for mission-critical tasks.
Why do we need this TimerInterrupt_Generic Library
Imagine you have a system with a mission-critical function, measuring water level and control the sump pump or doing something much more important. You normally use asoftware timer to poll, or even place the function in loop(). But what if another function is blocking the loop() or setup().
So your function might not be executed on-time or not at all, and the result would be disastrous.
You'd prefer to have your function called, no matter what happening with other functions (busy loop, bug, etc.).
The correct choice is to use a Hardware Timer with Interrupt to call your function.
These hardware timers, using interrupt, still work even if other functions are blocking. Moreover, they are much more precise (certainly depending on clock frequency accuracy) than other software timers using millis() or micros(). That's necessary if you need to measure some data requiring better accuracy.
Functions using normal software timers, relying on loop() and calling millis(), won't work if the loop() or setup() is blocked by certain operation. For example, certain function is blocking while it's connecting to WiFi or some services.
The catch is your function is now part of an ISR (Interrupt Service Routine), must be lean and mean, and follow certain rules. More to read on:
HOWTO Attach Interrupt
Important Notes:
1. Inside the ISR function, delay() won’t work and the value returned by millis() will not increment. Serial data received while in the ISR function may be lost. You should declare as volatile any variables that you modify within the attached function.
2. Typically global variables are used to pass data between an ISR and the main program. To make sure variables shared between an ISR and the main program are updated correctly, declare them as volatile.
Releases v1.2.0
1. Add STM32_TimerInterrupt Library
Releases v1.1.0
1. Initial Super-Library coding to merge all TimerInterrupt Libraries
Currently Supported Boards
- ESP8266
- ESP32
- AdaFruit Feather nRF52832, nRF52840 Express, BlueFruit Sense, Itsy-Bitsy nRF52840 Express, Metro nRF52840 Express, NINA_B302_ublox, NINA_B112_ublox etc..
- Arduino SAMD21 (ZERO, MKR, NANO_33_IOT, etc.).
- Adafruit SAM21 (Itsy-Bitsy M0, Metro M0, Feather M0, Gemma M0, etc.).
- Adafruit SAM51 (Itsy-Bitsy M4, Metro M4, Grand Central M4, Feather M4 Express, etc.).
- Seeeduino SAMD21/SAMD51 boards (SEEED_WIO_TERMINAL, SEEED_FEMTO_M0, SEEED_XIAO_M0, Wio_Lite_MG126, WIO_GPS_BOARD, SEEEDUINO_ZERO, SEEEDUINO_LORAWAN, SEEED_GROVE_UI_WIRELESS, etc.)
- STM32 (Nucleo-144, Nucleo-64, Nucleo-32, Discovery, STM32F1, STM32F3, STM32F4, STM32H7, STM32L0, etc.).
- STM32F/L/H/G/WB/MP1 (Nucleo-64 L053R8,Nucleo-144, Nucleo-64, Nucleo-32, Discovery, STM32Fx, STM32H7, STM32Lx, STM32Gx, STM32WB, STM32MP1, etc.) having 64K+ Flash program memory.
- Teensy boards such as :
- Teensy 4.1, 4.0
- Teensy 3.6, 3.5, 3.2/3.1, 3.0
- Teensy LC
- Teensy++ 2.0 and Teensy 2.0
- Arduino AVR boards such as :
- Arduino Uno / Mega / Leonardo / Duemilanove / Diecimila / LilyPad / Mini / Fio / Nano etc.
- Sanguino
- ATmega8, 48, 88, 168, 328
- ATmega8535, 16, 32, 164, 324, 644, 1284
- ATmega64, 128
- ATtiny 84 / 85
- Arduino SAM DUE.
Examples:
A. STM32F/L/H/G/WB/MP1
1. Argument_None
2. ISR_16_Timers_Array
3. ISR_RPM_Measure
4. ISR_Timer_Complex
5. RPM_Measure
6. SwitchDebounce
7. TimerInterruptTest
8. TimerInterruptLEDDemo
and there are many examples for AVR, ESP8266, ESP32, SAMD, SAM DUE, nRF52, Teensy, etc.
Debug Termimal Output Samples
1. The following is the sample terminal output when running example ISR_Timer_Complex on STM32F7 Nucleo-144 F767ZI using Built-in LAN8742A Ethernet and STM32Ethernet Library to demonstrate the accuracy of ISR Hardware Timer, especially when system is very busy. The ISR timer is programmed for 2s, is activated exactly after 2.000s !!!
While software timer, programmed for 2s, is activated after 9.782s !!!. Then in loop(), it's also activated every 3s.
Starting ISR_Timer_Complex on NUCLEO_F767ZI
Version : 1.2.0
CPU Frequency = 216 MHz
STM32TimerInterrupt: Timer Input Freq (Hz) = 216000000, _fre = 1000000.00, _count = 50000
Starting  ITimer OK, millis() = 6
[9] MAC:FE-E1-88-EC-DD-95
2s: Delta ms = 2000
2s: Delta ms = 2000
[6626] IP:192.168.2.116
[6626]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.6.1 on STM32 NUCLEO_F767ZI
[6636] BlynkArduinoClient.connect: Connecting to account.duckdns.org:8080
[6721] Ready (ping: 6ms).
IP = 192.168.2.116
2s: Delta ms = 2000
blynkDoingSomething2s: Delta programmed ms = 2000, actual = 9782
2s: Delta ms = 2000
5s: Delta ms = 5000
2s: Delta ms = 2000
blynkDoingSomething2s: Delta programmed ms = 2000, actual = 3000
2s: Delta ms = 2000
5s: Delta ms = 5000
2s: Delta ms = 2000
2s: Delta ms = 2000
2s: Delta ms = 2000
5s: Delta ms = 5000
2s: Delta ms = 2000
11s: Delta ms = 11000
2s: Delta ms = 2000
5s: Delta ms = 5000
2s: Delta ms = 2000
2s: Delta ms = 2000
2s: Delta ms = 2000
5s: Delta ms = 5000
2s: Delta ms = 2000
2s: Delta ms = 2000
5s: Delta ms = 5000
2s: Delta ms = 2000
2. The following is the sample terminal output when running example TimerInterruptTest on STM32F7 Nucleo-144 F767ZI to demonstrate how to start/stop Hardware Timers.
Starting TimerInterruptTest on NUCLEO_F767ZI
Version : 1.2.0
STM32TimerInterrupt: Timer Input Freq (Hz) = 216000000, _fre = 1000000.00, _count = 1000000
Starting  ITimer0 OK, millis() = 108
STM32TimerInterrupt: Timer Input Freq (Hz) = 108000000, _fre = 1000000.00, _count = 3000000
Starting  ITimer1 OK, millis() = 119
Stop ITimer0, millis() = 5001
Start ITimer0, millis() = 10002
Stop ITimer1, millis() = 15001
Stop ITimer0, millis() = 15003
Start ITimer0, millis() = 20004
Stop ITimer0, millis() = 25005
Start ITimer1, millis() = 30002
Start ITimer0, millis() = 30006
Stop ITimer0, millis() = 35007
Start ITimer0, millis() = 40008
Stop ITimer1, millis() = 45003
Stop ITimer0, millis() = 45009
Start ITimer0, millis() = 50010
Stop ITimer0, millis() = 55011
Start ITimer1, millis() = 60004
Start ITimer0, millis() = 60012
Stop ITimer0, millis() = 65013
Start ITimer0, millis() = 70014
Stop ITimer1, millis() = 75005
Stop ITimer0, millis() = 75015
Start ITimer0, millis() = 80016
Stop ITimer0, millis() = 85017
Start ITimer1, millis() = 90006
Start ITimer0, millis() = 90018
Stop ITimer0, millis() = 95019
Start ITimer0, millis() = 100020
Stop ITimer1, millis() = 105007
Stop ITimer0, millis() = 105021
Start ITimer0, millis() = 110022
Stop ITimer0, millis() = 115023
Start ITimer1, millis() = 120008
Start ITimer0, millis() = 120024
Stop ITimer0, millis() = 125025
Start ITimer0, millis() = 130026
Stop ITimer1, millis() = 135009
Stop ITimer0, millis() = 135027
Start ITimer0, millis() = 140028
khoih-prog
Re: TimerInterrupt_Generic Library to merge all TimerInterrupt Libraries
Releases v1.3.1
1. Add many complex examples.
2. Add board Version String.
3. Fix SAMD bug.
Releases v1.3.0
1. Add NRF52_MBED_TimerInterrupt Library to support NRF52840-based board using mbed-RTOS such as Nano-33-BLE.
2. Add support for UNO, Nano, Mini, Arduino Ethernet, Fio, BT, LilyPad, Pro, Pro Mini, NG, UNO WiFi.
Examples for STM32F/L/H/G/WB/MP1
1. Argument_None
2. ISR_RPM_Measure
3. ISR_Timer_Complex
4. RPM_Measure
5. SwitchDebounce
6. TimerInterruptTest
7. TimerInterruptLEDDemo
8. ISR_16_Timers_Array
9. ISR_16_Timers_Array_Complex
10. Change_Interval
