STM32 and Arduino Uno like USB to UART
Posted: Sat Nov 04, 2017 6:03 pm
by 7erduk
I want flashing my STM32F103. I don't have converter USB to UART, but have Arduino UNO. It cans be work like converter.
My system is maxOs SIerra.
I used software:
1. git clone https://github.com/rogerclarkmelbourne/ ... loader.git
2. git clone https://github.com/rogerclarkmelbourne/ ... _STM32.git
a. Arduino uno reset pin to ground.
b. Arduino uno 3.3V to STM 3.3V , groung to ground
c. Arduino uno 0 (RX) and 1 (TX) to STM32 A9 and A10 (i try change pins between each other)
d. STM32 boot0 is power, boot1 is ground
and i try flashing like that
./stm32flash -w ../../../../STM32duino-bootloader/binaries/generic_boot20_pa9.bin /dev/tty.usbmodem1431
results is
 Using Parser : Raw BINARY
Error probing interface "serial_posix"
Cannot handle device "/dev/tty.usbmodem1431"
Failed to open port: /dev/tty.usbmodem1431
i tried used another device /dev/cu.usbmodem1431, error is same.
also i checked my arduino uno usb to uart, i used bluetooth and send AT command, it's work with same configuration.
Maybe somebody had solved this problem? Thank you.
Re: STM32 and Arduino Uno like USB to UART
Posted: Sat Nov 04, 2017 8:29 pm
by RogerClark
There are a few new members who seem to be having problems with thus sort of thing.
Look in the active topics and see if their problems are the same as yours.
BTW. The sources for stm32flash are in the repo, so you could add some debug and recompile, to try to track down why its having a problem with that usb serial driver
Posted: Sat Dec 16, 2017 10:52 am
if you have a maple mini (or clone, e.g. Baite MM) with a pre-installed boot loader
you may like to try out this code i've posted under code snippets section, i'm not too sure if those codes would after all work on other arduinos
viewtopic.php?f=18&t=2752
one of those things that's needed by the stm32's built-in serial(uart) boot loader is that it needs an 8 (bits word size) E (even parity) 1 (stop bits) to communicate.
http://www.st.com/resource/en/applicati ... 264342.pdf
Posted: Sat Dec 16, 2017 2:38 pm
by victor_pv
Thanks! I have been trying to flash one thru an ESP8266, and was suspecting it was that but didn't know for sure. That saves me some time.
Posted: Sat Dec 16, 2017 7:10 pm
that's an interesting addition, now stm32duino can do over-the-air updates via esp8266 :lol:
Posted: Sun Dec 17, 2017 1:52 am
by mrburnette
Oh, my head hurts :shock:
Posted: Sun Dec 17, 2017 6:03 am
ot: but i'm not too sure when would stm make a stm32 with integrated bluetooth or wifi radios :lol:
