FT232H - setting DTR high or to input
Post by Pito » Sun Feb 11, 2018 11:25 am
Any idea how to set DTR (active low output) of the FT232H (working in UART mode) to "high" or to "input mode"?
PS: Without writing some low level drivers or apps..
Re: FT232H - setting DTR high or to input
Post by ahull » Sun Feb 11, 2018 5:38 pm
I have no clue.. do the datasheet and programmers guide not provide any clues?
Vassilis
Post by Vassilis » Mon Feb 12, 2018 9:42 am
Under windows, you can use the termite software to set/clear the DTR output.
Click on DTR icon as it is seen on the picture.
Post by Pito » Mon Feb 12, 2018 4:46 pm
DTR blinks with termite. Thanks.
A pity TeraTerm is missing it..
Post by ahull » Mon Feb 12, 2018 4:47 pm
For completeness here is a good example of how to do the same sort of thing using linux (and probably Mac OS/X).
Setting DTR,RTS etc programatically (from bash or whatever) follow this post -> https://forums.gentoo.org/viewtopic-p-8 ... ml#8132756
The trick is to access <sys/ioctl.h> and thus control the tty device at a fairly low level.
You might also be able to mess with the stty command to do the same thing.
Hope this helps.
Post by Pito » Wed Feb 14, 2018 9:09 am
In TeraTerm you may set/reset the DTR or RTS with "macros" (Control->Macro, you have to create a .ttl file with the command(s)).
setdtr 0/1
setrts 0/1
