Page 1 of 2
Programming with a BMP on Arduino 1.6.9
Posted: Mon Jul 04, 2016 12:31 am
by Darius
Hi all,
I'm just trying out STM32Duino and so I cloned https://github.com/rogerclarkmelbourne/ ... _STM32.git and checked out the development branch.
I twiddled STM32F1/platform.txt to change 'runtime.tools.arm-none-eabi-gcc.path' to point to my build environment.
The build worked but flashing didn't - it wouldn't run GDB.
In the end I modified platform.txt like so
tools.bmp_upload.cmd=/opt/local/bin/arm-none-eabi-gdb
tools.bmp_upload.upload.pattern="{cmd}" -cd "{build.path}" -b {upload.speed} {upload.verbose} -ex "set debug remote 0" -ex "set target-async off" -ex "set remotetimeout 60" -ex "set mem inaccessible-by-default off" -ex "set confirm off" -ex "set height 0" -ex "target extended-remote {serial.port}" -ex "monitor swdp_scan" -ex "attach 1" -ex "x/wx 0x8000004" -ex "monitor erase_mass" -ex "echo 0x8000004 expect 0xffffffff after erase\n" -ex "x/wx 0x8000004" -ex "file {build.project_name}.elf" -ex "load" -ex "x/wx 0x08000004" -ex "tbreak main" -ex "run" -ex "echo \n\n\nUpload finished!" -ex "quit"
i.e. call arm-none-eabi-gdb directly.
After that I can flash it and the blink example works.
I'm not sure what the 'right' answer is for the GDB issue..
Re: Programming with a BMP on Arduino 1.6.9
Posted: Mon Jul 04, 2016 12:45 am
by RogerClark
You can try PM'ing @rickKimball, he added the BMP code and is the expert in this
Or try finding the thread about the BMP and post there, as Rick normally responds to that thread
Posted: Mon Jul 04, 2016 1:04 am
by Darius
OK thanks.
Is there a canonical way to point Arduino to the tool chain, or is editing platform.txt it?
Posted: Mon Jul 04, 2016 1:22 am
by RogerClark
Darius wrote:OK thanks.
I'm not sure quite what you mean
Where the IDE hides the toolchain varies depending on OS and also the IDE verison (its in a different location on WIndows between verison 1.6.5 and 1.6.9)
When I build the bootloader using the Make command, I had to add the path to the Windows %PATH evn var
I just looked at the verbose output from the IDE and then added the gcc bin folder to my PATH
So I can now get to gcc and gdb etc on the command line and in Make, without needing the full path.
Posted: Mon Jul 04, 2016 1:24 am
by Darius
OK, I'll try putting it in my path and see how I go.
I didn't originally because I have arm-none-eabi-gcc v5.1.0 in my path - I downloaded 4.8 from Launchpad and put it in another directory because the boot loader repo suggests it doesn't work on any newer version.
Posted: Mon Jul 04, 2016 2:07 am
by RogerClark
Ah OK
I see you are running Linux
Rick, who added BMP support also uses Linux, so it does work on some distro's , but perhaps not yours.
Can you post any more questions to this thread
http://www.stm32duino.com/viewtopic.php?t=122
(If I get time I would move the thread myself, but I don't want to break the other thread as its an important source of information)
Posted: Mon Jul 04, 2016 2:15 am
by Darius
I'm using OSX (Launchpad now host the official ARM GCC builds).
I'll take a look at that thread, thanks.
Posted: Mon Jul 04, 2016 2:19 am
by RogerClark
OK
It may not have been tested on OSX
Posted: Mon Jul 04, 2016 2:43 am
by Rick Kimball
Darius wrote:Hi all,
Why did you have to "twiddle" the platform.txt? If you install either the Board package for the Arduino Due or Zero ( better as you also get openocd for free) you should get a working arm-none-eabi-gcc toolchain with all the fixings.
Turn on verbose upload options in File/Preferences and post your output showing the failure.
Have you tested your BMP setup by hand? Does that work properly? I've not tested any of this recently. I think at one point I did try this on OS/X but I don't remember what version of OS/X it was maybe 10.11? Currently, I don't think I even have a BMP board configured at the moment. To be honest, I've just been using either an STLink clone, a Nucleo Board or a Discovery Board to program and debug.
-rick
Posted: Mon Jul 04, 2016 2:57 am
by Darius
I posted my reply to http://www.stm32duino.com/viewtopic.php ... 531#p15531
