Can BMP debug without 'load' command.
alex
Post by alex » Thu Aug 25, 2016 4:59 pm
I mean just keep the .elf in the PC without flash it into the mcu, is it possible?
Rick Kimball
Re: Can BMP debug without 'load' command.
Post by Rick Kimball » Thu Aug 25, 2016 7:17 pm
Sure, just foo.elf file on the arm-none-eabi-gdb command line when you connect
$ arm-none-eabi-gdb ... all other gdb args .. myprog.elf
Just don't use the load if myprog.elf is the actual code loaded on the chip.
-rick
alex
Post by alex » Fri Aug 26, 2016 4:34 am
Rick Kimball wrote:Sure, just foo.elf file on the arm-none-eabi-gdb command line when you connect
I mean if gdb or BMP can take place of the mcu's flash in some way.
I know gdb can load .elf to mcu's RAM by change link script (eg the .ld).
RogerClark
Post by RogerClark » Fri Aug 26, 2016 6:01 am
BTW.
Running in ram used to be an option in the board menu's but as the sketch now generally takes at least 12 to 15k there is so little ram left in the smaller boards, that it wasn't worth supporting
But if you look in the old leaflabs github libmaple repo you can probably find the linker settings for it (albeit that would include the bootloader, which you are not using), but it would be a start.
alex
Post by alex » Fri Aug 26, 2016 10:20 am
RogerClark wrote:BTW.
I knew how to running in ram already, to changed the .ld file like this for a 48KB ram mcu
MEMORY
rom (rx) : ORIGIN = 0x20000000, LENGTH = 36K
ram (rwx) : ORIGIN = 0x20009000, LENGTH = 12K
and change SCB_VTOR in code
SCB_VTOR = 0x20000000;
What I want to know is can I make BMP and gdb to act as "fake external flash".
