simpler black magic probe in platform.txt
Post by Rick Kimball » Tue Nov 07, 2017 5:38 pm
I noticed that the tool.bmp_upload section of platform.txt is overly complex. : ) I'm not sure what I was thinking when I put that together. This replacement works just fine:
simpler wrote:# blackmagic probe upload
tools.bmp_upload.cmd=arm-none-eabi-gdb
tools.bmp_upload.path={runtime.tools.arm-none-eabi-gcc.path}/bin/
tools.bmp_upload.upload.speed=115200
tools.bmp_upload.upload.params.verbose=-batch
tools.bmp_upload.upload.params.quiet=--batch-silent
tools.bmp_upload.upload.pattern="{path}{cmd}" -cd={build.path} -ex "file {build.project_name}.elf" -nh -b {upload.speed} {upload.verbose} -ex "target extended-remote {serial.port}" -ex "monitor swdp_scan" -ex "attach 1" -ex "stop" -ex "mon erase_mass" -ex "load"
You will note I removed the (") around the -cd= target. This is because it was complaining on linux. I'm not sure if what I did works on windows or os/x. Maybe someone could try : )
Re: simpler black magic probe in platform.txt
Post by Rick Kimball » Thu Nov 09, 2017 6:09 pm
Normally I run putty as a terminal program when I'm using serial output. However, lately I've been trying to use the features offered by the Arduino IDE. The setup for Black Magic Probe uploading isn't optimal. I was thinking it would make more sense if we specified the BMP upload port in the boards.txt instead of using the currently selected port on the Arduino IDE.
Here is the change I made to the platform.txt:
tools.bmp_upload.upload.pattern="{path}{cmd}" -cd={build.path} -ex "file {build.project_name}.elf" -nh -b {upload.speed} {upload.verbose} -ex "target extended-remote {upload.port}" -ex "monitor swdp_scan" -ex "attach 1" -ex "stop" -ex "mon erase_mass" -ex "load"
Then I created a custom bluepill entry in boards.txt:
bluepill.name=Blue Pill (128k/via Black Magic Probe)
bluepill.build.board=GENERIC_STM32F103C
bluepill.build.core=maple
bluepill.build.cpu_flags=-DMCU_STM32F103CB
bluepill.build.f_cpu=72000000L
bluepill.build.flags.ldspecs=
bluepill.build.flags.optimize=-Os -g
bluepill.build.ldscript=ld/jtag.ld
bluepill.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG
bluepill.build.variant=generic_stm32f103c
bluepill.build.vect=VECT_TAB_ADDR=0x8000000
bluepill.upload.file_type=bin
bluepill.upload.maximum_data_size=20480
bluepill.upload.maximum_size=131072
bluepill.upload.port=/dev/ttyACM0
bluepill.upload.protocol=gdb_bmp
bluepill.upload.tool=bmp_upload
I'm on linux so I used port=/dev/ttyACM0 for the BMP GDB port and in the IDE I selected /dev/ttyACM1, This allows me to upload without have to switch the board between the GDP port (ttyACM0) and the Virtual Com port (ttyACM1). You would have to change the board.txt port for windows.
Post by RogerClark » Thu Nov 09, 2017 9:40 pm
I will update platform.txt when I get chance
Post by RogerClark » Sun Dec 03, 2017 6:15 am
Rick
I just noticed that this
will only work on Linux, its also specific to your machine which does not have another USB to serial device plugged in which could be on ttyACM0
There is a change for Windows which would address this, using one of the Windows built in functions to look though the USB devices looking for a specific name e.g. BMP debug
Something like this
@ECHO off
setlocal enabledelayedexpansion
for /F "skip=1 tokens=*" %%a in ('wmic path Win32_SerialPort Where "Caption LIKE '%%Black Magic GDB Server%%'" Get DeviceID') do if not defined id set id=%%a
Call Set "commport=%%id: =%%"
arm-none-eabi-gdb -quiet  -b 230400 -ex set debug remote 0 -ex set target-async off -ex set remotetimeout 60 -ex set mem inaccessible-by-default off -ex set confirm off -ex set height 0 -ex "target extended-remote \\.\%commport%" -ex monitor swdp_scan -ex attach 1 -ex file %1 -ex load -ex tbreak main -ex run -ex echo \n\n\nUpload finished! -ex quit
rem:
pause
But I"d need to use an external script for BMP upload rather than just using the line in platform.txt which directly sends commands to GDB
Post by Rick Kimball » Sun Dec 03, 2017 3:34 pm
The first version is probably best for a general purpose one. It acts just like the current one with less arm waving:
My second "enhanced" version was only posted as an example of how I modified my personal configuration so I don't have to switch between the tty ports while using the Arduino IDE. This is probably not fit for public consumption. I should have indicated that in my post.
BTW: my goal with using gdb + bmp was to avoid any extra scripts or commands required to write to flash. arm-none-eabi-gdb is downloaded as part of the compiler so it doesn't require any extra scripts. In theory this should reduce maintenance : )
Post by RogerClark » Sun Dec 03, 2017 9:39 pm
Thanks Rick
I don't have a big problem with the external scripts, but the external tools especially things like Leaflabs maple loader jar are a bigger support issue.
Especially as Leaflabs never released the source to the maple loader jar, and we had to decompile it to get some source
