Simple guide to make BMP on Baite?
Nutsy
Post by Nutsy » Mon Jan 22, 2018 11:32 am
Hi i must admit ive been doing a fair bit of reading of the topics here... And im still none the wiser...
So I've gathered its possible to make a BMP from a Baite Maple mini. But from possible finding some prebuilt firmware, I dont know how to make it work?
I guess what im after is a straight forward guide to making one?
Or at the least a pinout for the Baite maple version of the probe?
Out of interest though, does a BMP provide full jtag? Or is it a simplified firmware only like the stlink?
Re: Simple guide to make BMP on Baite?
Post by zmemw16 » Mon Jan 22, 2018 12:37 pm
i put 'black magic probe' in the search box and 368 entries
viewtopic.php?f=37&t=2802&hilit=black+magic+probe
then i added 'bin' 32 entries
viewtopic.php?f=37&t=1723&p=22635&hilit ... bin#p22635
and then inspiration struck, added 'zip'
viewtopic.php?f=37&t=122&p=989&hilit=bl ... n+zip#p989
ok i quite like the thing, CubeMX - pick a chip, almost any chip and cycle through the debug option under the sys device, it hi-lights the pins being used in each mode, for serial trace 3 wire mode?
it will also generate the hardware initialisation and release call as boilerplate code, useful for addresses, masks and values.
easier maybe than reading the data sheet and the PM/RM pdf's.
Post by mrburnette » Mon Jan 22, 2018 12:39 pm
Nutsy:
viewtopic.php?t=1723
As a start ... the Blue Pill ... is the recommended board and it may require modifications. In my mind, you may have to gut the USB on the MM to get BMP to work.
Post by zmemw16 » Mon Jan 22, 2018 12:46 pm
:lol: intention :lol:
ok just give the man the fish, me fishing rod and tackle, not quite the right baite though
:lol: :lol:
Post by Rick Kimball » Mon Jan 22, 2018 2:34 pm
You shouldn't waste your time with a Baite MM port unless you are in it for the educational value. Just buy a blackpill and load the binary found here: viewtopic.php?f=37&t=2801
Yes. However, I'm not sure what you gain as it uses a lot more pins and recent changes to Roger's core will cause you nothing but grief in trying to use it.
